Previous in Forum: Boiler Drums and Level Indicators   Next in Forum: instrumentation
Good Answers: 18
Level Measurement Instrument
07/01/2009 8:13 AM
For all inquiries I've seen for non-contact, level measurement posted on CR4, I'm sure that this information will come in handy for several people.
I just ran across this (as I'm sure others have) from Engineer Live: Level Measurement Non-Contact Sensors Mounted Outside Vessel
Pathfinder Tags: level measurement non-contact
Re: Level Measurement Instrument
07/01/2009 11:31 AM
Prior experience with capacitance level suggests that all is well until the material in the vessel changes. A consequent change in permittivity runs the risk of either measuring short or of overfilling, if relying on the instrument alone. Given that capacitance needs to be viewed as a last resort technique for measuring level, the consequences of the latter could be disastrous.
Use with caution.
Good Answers: 18
07/01/2009 11:43 AM
Funny you should mention that . . .
I fiddled around with the capacitive concept several years ago and never got it to perform with anything close to repeatable or reliable, so I figured, what the hell, I'll do it another way.
By the way, there are problems with bouncing ultrasonic beeps off the surface of some liquids too.
Good Answers: 109
07/02/2009 4:33 PM
To overcome this problem usually there are two sensors, one as suggested and the reference one at the bottom of the container.
Then you calculate (may be done in the primary sensor circuit) C1/Cref.
This can directly give voltages U1/Uref.
This is independent of fluid changes.
But: any stray capacitances pose considerable problems, elimination by guarding should be tried but also not simple.
RHABE
07/01/2009 2:05 PM
weight it
07/02/2009 1:56 PM
The U.S. Navy uses TLI's (tank level indicators) on all their fuel oil and other liquids, but they don't rely 100% on them . They always sound their tanks periodically through a deck mounted access plug.
Mr.Ron from South Ms.
Good Answers: 54
07/04/2009 7:27 AM
When all else fails, we tap on the side of the tank.
"Yup, it's about 50% full (or empty, depending on the type of person )".
regards,
Vulcan
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
07/10/2009 7:38 AM
well what I feel is the dielectric media that matter not so reliable
Register to Reply 7 comments
Anonymous Poster (1); Bill (1); find2am (1); PWSlack (1); RHABE (1); ronseto (1); Vulcan (1)
