Previous in Forum: sand casting risers   Next in Forum: ASME Section VIII - Div 02 Vessel
Safety Valve Body Repair Procedure
07/07/2009 1:29 PM
Safety valve body repair procedure needed:
Observation: The steam safety valve body - nozzle fixing threaded area found to have eroded
This erosion (observation) had been seen in superheater safety valve as well as in saturated steam safety valve. The depth of erosion is 10 mm MAX. around the nozzle for a height of 3 inches. The top portion of the thread got eroded.
The material of the saturated steam safety valve is A217 Gr WCB and the material for the superheated steam safety valve is A217 Gr WC9.
Pathfinder Tags: ssmv123
Re: Safety Valve Body Repair Procedure
07/07/2009 9:03 PM
Do you require a VR stamp from the National Board?
http://www.nationalboard.org/Index.aspx?pageID=115&ID=161
Should you really just send the valve to a qualified repair shop? For example:
http://www.thorcoinc.com/relief-valve-repair.html
07/08/2009 3:44 AM
Change it for a new one, with original material and compliance certification. Repairs may not be worth the risk.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
07/08/2009 8:30 AM
Agreed replace and dispose. Some plants I have worked at kept an inventory of spare PSVs for just such an occasion.
Money doesn't talk, it screams in your face.
Register to Reply 3 comments
Anonymous Poster (1); betomachine (1); PWSlack (1)
