Previous in Forum: Technical Service - General Questions   Next in Forum: Pull Out Loading for Smooth Shank Nail
Engineering Fields - Piping Design Engineering - New Member
Single-Joint Mitre
07/07/2009 2:00 PM
I havnt seen mitre with single joint...I mean 2 piece mitre. Is there is any specific reason that we dont go for this option or very rare , if we go?
annu
Re: Mitre bend
07/07/2009 2:06 PM
pressure drop ......... energy loss is the reason.
Re: Single-Joint Mitre
07/08/2009 12:58 AM
I think there is no problem to use as specified single miter bend , only concern to check your required pressure drop for the system .if angular angle is more than 3 degree it will consider as miter bend as per ASME 31.3. miter bend may be single or multiple bend.
07/08/2009 3:42 AM
It is rare to find a 2-piece mitre in cabinet making. A stopped- or hidden-dovetail joint is more likely.
07/08/2009 8:31 AM
An imperfect mitre is difficult to disguise. Due to angle mismatch or slide-by when clamping. A dovetail or mortise and tenon joint hide minor imperfections better.
Register to Reply 4 comments
Daddio926 (1); munneykhan (1); PWSlack (1); ssmv123 (1)
