Previous in Forum: Diesel fuel polishing pump   Next in Forum: SWING CHECK VALVES
water pressure
07/07/2009 5:47 PM
what is the pressure at50 ft in water
Good Answers: 101
Re: water pressure
07/07/2009 6:07 PM
About 21.5 psi @ 60°F clean freshwater, but actually depends on water temperature and density. For example there will be a difference if water is sea water ~22psi @60°F, or freshwater~21.5 psi @60°F. Also the temperature will also greatly affect the pressure.
Re: water pressure
07/07/2009 6:12 PM
Water exerts a force of 0.433 PSI per foot of elevation.
Bud Trinkel
Re: water pressure
07/07/2009 7:22 PM
Homework, or going diving?
Good Answers: 143
Re: water pressure
07/07/2009 8:01 PM
40 ft of water, rounded off to the nearest 40 ft.
Good Answers: 101
Re: water pressure
07/07/2009 10:07 PM
50 feet of head.
Good Answers: 19
Re: water pressure
07/08/2009 12:35 AM
27" water column = 1 psi So 2'-3" = 1 psi. Divide 50 ft by 2.3 = your pressure
Re: water pressure
07/08/2009 9:19 AM
...it depends if you go head or feet first.
Dreams are the blue print for reality.
Register to Reply 7 comments
BudT (1); ducon (1); DVader1000 (1); lyn (1); Quobaldt (1); RVZ717 (1); TVP45 (1)
