Previous in Forum: Line Resolution and Frequency   Next in Forum: Relays vs. Alarms
Three Way Vale and 220-VAC
07/09/2009 6:15 AM
Hi there
Could anyone help me out there to find a three way valve that will allow the water to flow in one direction when OFF and other direction when ON using a 220VAc? Please let me know where to get it here in South Africa.
Best Regards.
Nganpet
Impossible n'est pas Camerounais
Re: 4 to 5 inch valve three way 220VAc in South Africa
07/09/2009 6:35 AM
Contact a local valves distributor directly. The distributor will want to know about line size, wetted materials, valve type, etc.
5 inch is not a regular line size. Try 6-inch instead.
07/09/2009 5:37 PM
you can accomplish the same effect with two valves an over sized actuator, two custom made couplers, and the proper piping sequence. Plus you wont have to deal with the leaking three way valve(havent had much luck with three way valves). Switched out everyone in the plant with this method. Cut back on a ton of work orders.
South Africa - Member -
Good Answers: 12
Re: Three Way Vale and 220-VAC
07/13/2009 1:26 AM
Hi there,
In SA try Tyco Valves: http://www.tycovalves.com
They will also help you source the valve if they are not a supplier of a specific make.
Cheers
Craig
07/24/2009 2:20 AM
Hi friend.
Three way sol valve mean 3 ports one in and 1 out and one vent. when u give 220 v ac coil energise and plunger will up out will open and vent will close and u denergise the coil out will close and vent will open.
regards
shahbaz ranjha
This is good place where technical people share their knowledge
Register to Reply 4 comments
craigza (1); moore (1); PWSlack (1); ranjha (1)
