Previous in Forum: Supplying a 6"-Pipe with a 3"-Water Supply   Next in Forum: Gas-Tight Doors
Wanted: High Pressure and High Volume Pumps
07/09/2009 9:52 AM
Pump No 1 : 160 ltr/sec @ 36440.5 kPa 4 Off
Pump No 2 : 160 ltr/sec @ 37816.5 kPa 4 Off
Pump No 3 : 160 ltr/sec @ 40650.9 kPa 4 Off
Pump No 4 : 160 ltr/sec @ 250 kPa 4 Off
Pump No 5 : 120 ltr/sec @ 1600 kPa 4 Off
Most companies out there are saying they do not have pumps of these duty points. Is there a company out there which can assist me
Friend of CR4
Re: LOOKING FOR THE FOLLOWING PUMPS
07/09/2009 10:02 AM
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
07/09/2009 10:41 AM
What you should look for are "high pressure oilfield pumps"
For example,
http://www.catpumps.com/pumps-chemical-injection-oilfield-high-pressure.asp
(but that is tough duty - especially with that flow)
Good Answers: 137
Re: Wanted: High Pressure and High Volume Pumps
07/10/2009 6:03 AM
What's the fluid? Pumps 1 - 3 look pretty special, but if you're on water Pump 4 is no problem. Pump 5 is fairly high pressure but as it's a biggish pump (150 - 200mm discharge dia., ~ 275 kW), one should be available.
Cheers.........Codey
Anonymous Poster (1); Chris Leonard (1); Codemaster (1)
