I own a 1996 Chevy Cavalier with a 2.2 and auto trans. I have changed the eng. block with one from the junk yard. I believe the block came out of a 1999 Cavalier. I installed a new timing chain and gear and double checked the alignment marks twice, removed and cleaned the head and installed a new head gasket, installed new plugs and gapped them at .060, installed the cam sensor and crank sensor from the 96. My problem is severe spark knock, and when I pulled the plugs, the #3 and #4 plugs were bent flat. This has been a real pain. Any help would be appreciated.
