Previous in Forum: Tariff Metering With Earthed Voltage Transformers   Next in Forum: acoustic enclosure of 320 kva genset
15 comments
United Kingdom - Member - British
Wiring US Plug - UK style
07/12/2009 5:18 AM
Hi. I have a Battery charger that has an US style plug on. It takes 100-240v~ 50/60Hz Max 150 mA. I live in the UK and was wondering how to wire it up. Would I need to wire the earth onto it anywhere? I have previously used a 12v adaptor and the 12v port on the top to charge my camera batteries (It is a lithium battery pack).
bondy111
Re: Wiring US Plug - UK style
07/12/2009 6:18 AM
The charger is Class II insulated (AKA double insulated), and doesn't need an earth connection.
Your only concern is how to connect the live & neutral to the power input pins safely. I'd suggest an adapter plug.
07/12/2009 6:47 AM
Two little bits of wire it is! :D
Is the pin on the left of the US plug the neutral and the one on the right the live?
bondy111
07/12/2009 6:49 AM
07/12/2009 9:07 AM
I, once, have used a connecting power cord with ends terminated with plugs. I still don't know why I have been fired
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
07/12/2009 9:29 AM
Was working on site recently, & had to PAT1 test a bit of kit (1500mm x 1000mm x 250mm steel wallbox, fed from a fused 13A spur. Method involves temporarily re-wiring mains power input using a length of mains cord & a plug. I didn't have the makin's with me so went scrounging in the handyman's den. I found two cordsets on a shelf, each made up with 2m of 3 core 13A cable to mains plug - cables had bare stripped & twisted ends.
Don't know what the hell he used them for - thought it better not to ask!
1 PAT = Portable Appliance Test. (Often wondered how this term can be applied to a wallbox as described above! Would almost need a forklift to carry it around, and that after unscrewing it from the wall.)
07/12/2009 9:16 AM
"Is the pin on the left of the US plug the neutral and the one on the right the live?" - doesn't matter in this app.
(Sorry, didn't notice this bit.)
07/12/2009 4:10 PM
07/12/2009 5:09 PM
yes, maybe putting 230v through two small pieces of wire isn't the best idea...
bondy111
07/13/2009 12:15 AM
If it is a polarized connector the neutral will have a wider blade at the end. The hot blade will have a constant width. If both are the same width it doesn't matter which is connected to the neutral and which to the hot.
07/13/2009 2:46 AM
The square-within-a-square symbol marked on the case indicates that it is double-insulated, and doesn't require an earth connection. The CE marking indicates pan-European approval for use.
Simply plug the thing into an overseas→UK travel adapter, and plug the travel adapter into a BS1363 13A domestic socket. "Robert is your mother's brother".
07/13/2009 11:11 AM
Get someone in the USA to send you the adapter or try to buy one at a british airport.
The biggest problem using the adapter is that it is possible to actually put your finger on a live pin with many of them.....a tiewrap to keep the two parts together at all times is a good idea........be careful.....
07/13/2009 11:18 AM
If you use an IEC (kettle) lead and some force, it will fit on these pins. I didn't say this and so am posting anonymously.
07/13/2009 11:41 AM
After much regret, I have bought an adaptor. That is another £3 that could have been spent elsewhere...
bondy111
07/13/2009 11:45 AM
... should've gone to the pound shop (or even the 'ninety-nine pee' shop).
07/13/2009 12:22 PM
It costs more to drive to there than to go onto eBay and buy one! My nearest one is over 20 miles away :D
bondy111
Register to Reply 15 comments
Andy Germany (1); Anonymous Poster (2); Bondy111 (4); indel (1); jack of all trades (1); JohnDG (5); PWSlack (1)
You might be interested in: Wire to Wire Connectors, Battery Holders
