Previous in Forum: Power Factor improvement.   Next in Forum: SLOPE IN THE DIFFERENTIAL RELAY
Minimum Distance from Ground
07/13/2009 1:43 PM
can anyone help? what is the minium distance from ground for 480Volts.
Good Answers: 143
Re: electrical distance
07/13/2009 3:21 PM
It would help if you tell us what code you live by and what's on the ground. Are you looking at NEC?
Re: Minimum Distance from Ground
07/13/2009 9:02 PM
Are you takling about 480V with bare wire or insulated wire.
07/14/2009 3:17 AM
It needs to be out of harm's way.
11kV is routinely run as bare conductor on brackets fitted to the top of wooden poles in rural districts here. At a guess, 5-6m above ground is the order of magnitude of the clearance, unless roadways etc. are underneath, in which case it may go to 7 or 8m with a protective earthed wire cradle underneath it.
07/14/2009 8:29 PM
Please consult your local electrical standards and regulations for the answer relevant to your country and site. Alternatively get an electrician to perform the electrical work. If you are building a product, buy the relevant electrical standards.
jack of all trades (1); PWSlack (1); Simon Wan (1); TVP45 (1)
