Previous in Forum: Calculating Orifice Size   Next in Forum: BOILER
Low Volume Variable Flow Positive Displacement Pump
07/13/2009 11:12 PM
I am looking for a supplier of of a reasonable cost pump that can provide the following:
Positive displacement. Discharge pressure up to 150 psig
Controllable flow in the milli-liters/hour range without needing to use a flow meter and recycle loop. Therefor, probably by controlling the motor speed.
Handle low amounts (a few percent or less) suspended solids
120 VAC power supply
Piston pumps with check valves fail due to the solids. I have found several vane pumps and gear pumps that would do the job but they require an accompanying converter to DC power supply. That will probably not be acceptable unless it is fully integrated into a single unit. (I really need a highly robust, fairly fool-proof unit.)
Thanks to anyone who can contribute the name of a pump and/or supplier.
Re: Low Volume variable flow Positive Displacement Pump
07/14/2009 3:29 AM
Look at dosing pumps, used to dose chemicals routinely into streams in water treatment applications. Gee, Milton Roy and Bran & Luebbe spring to mind (usual disclaimer).
India - Member - New Member
07/15/2009 12:55 AM
I recommand to use Diaphragm metering pumps for Explosive mixer / Hydrocarbon application (supplier as specified above). You can also check with Milton roy / OMG for small size metering pumps.
If application is not for explosive fluid, you can take Plunger pumps also.
For capacity Control - You can use either the following combination (In addition to Motor + VSD panel )
1. Manual - Stroke adjustment.
2. I2P Converter
3. Serve motor stroke control signal - Electonic 4-20 mA
With regards,
Nilesh.
Re: Low Volume Variable Flow Positive Displacement Pump
07/15/2009 9:15 AM
Consider a peristaltic (hose) pump with a VFD. Some will provide the 150 psi pressure, most are very rugged and accurate and will handle solids.
07/15/2009 9:24 AM
Good suggestion. Do they not require DC power supply to achieve variable motor speed that will give the variable flow control? Do you know a good vendor?
Thank you
07/15/2009 11:26 AM
Cole-Parmer, Verderflex, Watson-Marlow for a few vendors. Variable speed drive would probably be less than $500 but usually will be supplied with the smaller pumps.
07/15/2009 1:22 PM
Excellent
Thanks
07/15/2009 1:52 PM
My recommendation is to look at a Wanner Hydra-Cell pump. They are designed for high pressure and solids handling. Here is their website: http://www.hydra-cell.com/
Regards, Bob Sygiel
R.F. MacDonald Co.
Hayward, CA
Register to Reply 7 comments
Anonymous Poster (1); John Carberry (2); Nilesh (1); PWSlack (1); realist (2)
