Previous in Forum: Concrete Volute Cooling Water Pumps   Next in Forum: load calculation
India - Member - New Member
Fan or Blower?
07/14/2009 6:17 AM
Dear All,
I am looking for a vendor who can supply Fan/Blower for the following operating condition: -
Operating gas : - Ammonia
Suction pr./Temp. : - 1.033 kg/cm2 (a) / (-) 32.8 oC.
Discharge pr. / temp. : - 1.233 kg/cm2 (a) / (-) 30 oC.
Flow rate Normal / Rated : - 868 / 1042 m3/hr.
Approx. Fan power = 7.5 kw (calculated as per QH/102 Formula)
As, we have static pr. is approx. 2000 mm of water column, I think, Centrifugal blower can fulfill the required operating condition.
But, the problem is, almost all Fan/Blower vendors have regreted saying that operating parameters are not falling in their manufacturing range.
I discussed with my Process team but, they can not do any things better than what is specified above.
Can any one help me...
With regards,
Nilesh.
Pathfinder Tags: Vendor for Fan & Blower
Re: Fan or Blower
07/14/2009 6:29 AM
Is this fan for extracting the ammonia from a process, or it it intended to blow the ammonia in?
If it's going in, can the job be done another way, maybe by using bulk ammonia storage and letting it in using some sort of pressure-let-down valve?
Re: Fan or Blower
07/14/2009 6:34 AM
Dear Mr. PW Slack,
Your question is corret. I forget to detailed it our in my last thread.
Ammonia vapor from Ammonia storage tank shall be compressed (via. referred Fan/Blower) and send to Mix with other equipment inlet stream.
With regards,
Nilesh.
Re: Fan or Blower
07/14/2009 6:36 AM
PWSlack is a username and has no gender.
What is the temperature and pressure in the storage tank?
Good Answers: 137
Re: Fan or Blower
07/14/2009 9:59 AM
Nilesh
Utile Engineering make a range of fans and blowers. Links attached. 2-stage for 200mbar pressure rise. Looks as if one of those will do your duty. Due to the difference in density ammonia vs air, equivalent pressure rise on air is about 340mbar.
http://www.utileengineering.co.uk/documents/Mico-90-220.pdf
BTW, what does the (a) after your 1.033 kg/cm2 mean? Not absolute, from the context.
Cheers.......Codey
Re: Fan or Blower
07/15/2009 12:05 AM
atm. pressure = 1.033 kg/cm2 (absolute)
Good Answers: 137
Re: Fan or Blower
07/15/2009 3:42 AM
Yes, sorry, I was misreading it.
Can Utile offer anything?
Codey
Register to Reply 6 comments
Codemaster (2); Nilesh (2); PWSlack (2)
