Previous in Forum: New Alternator Died Instantly   Next in Forum: New Car
14 comments
fuel conservation for car engine
07/15/2009 3:10 AM
how i can save fuel in my car?
Re: fuel conservation for car engine
07/15/2009 3:38 AM
Going gently on the loud pedal helps.
07/15/2009 3:43 AM
Keep away all the unncessary items from your,dont treat your car as mobile store. Carry out regular maintenance , check the fuel burning condition - CO
07/15/2009 3:45 AM
Take the roof rack off when not in use.
07/15/2009 3:46 AM
Keep the tyres correctly inflated.
07/15/2009 3:47 AM
Make sure the wheel tracking is correct.
Good Answers: 137
07/15/2009 4:11 AM
Use it less often
Good Answers: 19
07/15/2009 4:49 AM
be less spontaneous, plan to combine your trips so you do a number of things with each journey.
use a bicycle when possible.
07/15/2009 5:46 AM
Take the bus instead.
Good Answers: 143
07/15/2009 7:39 AM
Imagine that you have a beaker of skunk oil sitting on the back floor. It is covered by a lid that prevents any of the odor escaping, but the lid will fall off it you jostle the beaker. Don't!
07/15/2009 10:18 AM
Smooooooooth, gentle acceleration when starting. Maintain a constant speed. Anticipate stopping as much as possible so that you can smoothly stop, too. Every time you apply the brakes, you've negated the fuel you just burned and turn it into waste heat at the brakes.
Air pressure, etc, etc as already mentioned.
Good Answers: 266
07/15/2009 4:45 PM
Walk more lots of people out of habit will go to the store in their car which is a few blocks away to get items that could be easily carried while walking.
Hobbies - Automotive Performance - education, never enough!
Location: latitude, 35.080N. longitude -106.387W. Abq. N.M.
07/15/2009 11:03 PM
This is one of the best sites regarding your topic. http://ecomodder.com/ There are over 100 hypermiling tips, plus go to the forum page. Many great aerodynamic enhancements, DIY information, equipment information etc. Take a look.
...the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed lest Rome become bankrupt. People must again learn to work, instead of living on public assistance. -- Cicero , 55 BC
07/16/2009 5:00 PM
Place it in a gas can, place the gas can in the back seat, then park the car.
When you want to get the fuel out of your car, open the back door and remove the gas can.
07/16/2009 11:09 PM
Assuming you have made certain the engine is in excellent condition and properly tuned, one suggestion that is rarely mentioned is keeping the RPM as low as possible. This is easy with a manual transmission: simply upshift early and drive as if an egg were under the accelerator pedal. This is much harder with an automatic transmission because they are usually programmed for quick acceleration rather than maximum economy especially when driving up an incline.
Dennis Waller
aikhh (1); Codemaster (1); DennisWaller (1); HUX (1); Labyguy (1); lyn (1); naturalextraction (1); ozzb (1); PWSlack (5); TVP45 (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
