Previous in Forum: Centrifugal Pump Suction and Cavitation Problem   Next in Forum: Flanged Ball Valve
Sizing Pipes for Gravity Flow Systems
07/15/2009 5:24 AM
Is there any specific prosedure or standard guide line for pipe sizing for natural flow.
Re: Steel pipe size for natural flow (under gravity)
07/15/2009 5:43 AM
What is the fluid?
07/15/2009 5:55 AM
Fluid : water
Over head tank fluid elevation : 1202 m (1197.0 tank elevation + 5 m water height in tank)
user point El. : 1105 .00
User point is connected through steel pipe from over head tank. At user point required pressure range is from 4 to 6 bar. What should be the size of connecting pipe if velocity limited upto 2.5 m/s.
07/15/2009 6:29 AM
What is the required flowrate?
07/15/2009 6:36 AM
Well, nice learning ..
Required flow may varry in the range of 54 m3/hr to 205 m3/hr.
07/15/2009 6:47 AM
0.057m3/sec at 2.5m/sec gives a cross-sectional area of the pipe as 0.022m2. Select a 200mm Ø pipe and there will be no problem with delivery pressure given the difference in elevations.
One might get away with 150mm Ø if one were prepared to run at higher than 2.5m/sec, depending on the overall length of the pipe.
There's oodles of pressure there.
Re: Sizing Pipes for Gravity Flow Systems
07/17/2009 12:13 PM
I agree with PWSlack that 150mm should be fine but that pushes the velocity up to 3.2m/s at 205m³/hr.
Presure drop at that speed in a steel pipe is about 0.5bar per 100m of pipe, so for between 4 and 6 bar at the outlet around a kilometer of pipe would be needed to naturally lower the outlet pressure or a considerably better idea would be to use a pressure regulating valve at the end of the line just upstream of the outlet and keep your pipe lenght to a minimum.
Whats this for, as thats a huge amount of water to be moving? (Hint - School is the wrong answere :) )
Anonymous Poster (2); PWSlack (3); shanemcconn (1)
