Previous in Forum: Sizing Pipes for Gravity Flow Systems   Next in Forum: Snuffer Rings
8 comments
Flanged Ball Valve
07/15/2009 8:49 AM
Hi guys, Is there any body know which manufacturer is doing 1" 2500Lb & 300dgC flanged ball valve?
Pathfinder Tags: high pressure ball valve
Re: 1" 2500Lb & 300dgC flanged ball valve
07/15/2009 8:53 AM
Contact a local valves distributor.
Good Answers: 101
Re: Flanged Ball Valve
07/15/2009 11:22 AM
DMIC
07/16/2009 12:16 AM
Dear sir,
You goodself is from which part of globe? you may google for correct answer,there are few manufactueres are here in INDIA.
Thank you.
V.D.DEODHAR.
07/16/2009 2:39 AM
Howdy, Try the supply line S.A.
thesupplyline.com.au
Cheers BoZo
Good Answers: 68
07/16/2009 9:54 AM
Hello maizi,
Try this site. Not sure where you are but if you can tell me the Country I can try and find one nearer to where you work?
NOTE:
The site below have a drop-down menu to allow you to choose any area world wide.!!!!!!!!!!
http://www.swagelok.com/valves/ball-valves/index.htm?gclid=CKGdwvOu2psCFZgU4wodvl7s-A
http://www.tycoflowcontrol-na.com/ld/KTMMC-0505-US.pdf
http://www.google.com/search?hl=en&client=safari&rls=en-gb&ei=aC5fSufJMo6sjAe5vJnaDQ&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=1%22+2500+Lb+%26+300dgC+flanged+ball+valve&spell=1
Ball Valves for Industry Ball valves from our massive stock High & Low pressure www.isis-fluid.co.uk
Worcester Valve Stockist Largest UK stock. Next day delivery Actuated packages built in house.
www.PeglerAndLouden.com High Pressure Ball Valves 2 & 3-Way, 5000 to 20000 psi 3/16", 1/4", 3/8" and 1/2" orifice
www.highpressure.com Air tools & Pneumatics Air Drills, Guns, Hammers Air Cylinders, coupling, hoses
www.airchannel.co.uk Ball Valves MGA Controls - your one stop shop for control & instrumentation
www.mgacontrols.co.uk Tube, Valves & Fittings Salmons (Southwater) Stockist of Malleable Fittings 01403 731 322
www.hydraquip.co.uk Lever Ball Valve Lever Ball Valve Stanard Pattern All Sizes - Next Day Delivery
www.aquamation.co.uk/Great-Prices Ball valve Fast, free next day delivery. A huge choice of products to order. uk.rs-online.com
07/17/2009 5:35 PM
To Whom It May Concern:
Thank you for giving me the opportunity to briefly introduce to you, a complete line of high-quality valves, manufactured by Global Valve and Controls.
GVC prides itself for excellent 100% customer service; expert technical support; competitive pricing; and a large inventory of "in-stock" valves. Our inventory is always well-stocked and ready for immediate delivery: we can save your company time and money, without the frustration of week(s) delays in shipment.
  • Ball, Gate, Globe and Check Valves in ANSI 150 -2500
(In-Stock, Ready for Immediate Delivery)
  • Alloy 20, Monel, Duplex, Carbon Steel and Stainless Steel valves and accessories .(In-Stock, Ready for Immediate Delivery)
  • ANSI 150 through 2500 in sizes up to 36" in both Trunnion and Floating design
§ Basic designs meet the following standards: Fire safe to API 607 4th Edition, API 6D, API 598, B16.10, B16.5, B16.34, NACE MR-0175
§ API 6D pipeline valves in stock up to 24" ANSI 600 ,double block and bleed design
§ 6000 psi Full Port, Threaded Ends, NACE, Carbon Steel and Stainless Steel Construction with ISO Mounting Pad with Handle and Locking Device in sizes 1/4" through 2"
§ Three piece design, Fire safe, 2000 psi, Full Port, Inline Weldable, Live Loaded Stem design in CN7M (Alloy 20), CF8M (316 Stainless) and WCB (Carbon Steel), ISO Mounting Pad with Handle and Locking Device and optional Media Containment Bonnet units for hazardous services
§ Standard ISO Mounting Pad in Series: 3T, T, E1, FS 150/300/600, FS525, D525, 20RP, BV6000
§ Lockout devices standard on all threaded and socket valves (except BV2000)
§ Wide variety of high temperature seats and seals such as Super Nova, PEEK, TFM, Vespel, Devlon, and Metal.
§ Investment cast on sizes up to 6"
§ Multi-port Valves in Carbon Steel and Stainless Steel
§ Full line of Spring Return and Double Acting actuators with linkage kits and accessories
Please visit our website www.globalvalveandcontrols.com if you would like to view our catalog which includes detailed drawings, cut sheets and technical data. CMTRs are available on all valves upon request
Thank you for your time and consideration! I look forward to talking to you soon, so that we may begin to form a long-lasting business relationship! If you have any questions, you can reach me at: 281-463-1474
Regards,
Nina Prohorenko, 832-380-0525, nprohorenko@gvcintl.com
07/20/2009 8:20 AM
Thanks guys. It seems there is no suitable products which I wanted here. As the information all you mentioned and which I could find on the google, most ball valve could meet the high pressure requirements but not flanged connection. Or, to lack with the high temperature condition. Anyway, thanks all of you guys. I am going to try to use globe valve to instead ball type one. It seems more make sense.
Good Answers: 68
07/20/2009 10:45 AM
Hello maizi,
Your specific request was for "flanged ball valves".
There may be a difference in the term "ball valve" used here.
Do you mean a 'floating ball valve' where the float uses the pressure of the filling tanks water to shut off the valve.
Or a 'ball shaped valve', which is used 'in-line' to alter the direction or turn the water on and off?
This site below most definitely has "flanged ball valves, but, whether they are what you want I cannot say. Can you explain what you want to do and where in the system you wish yo fit it please?
http://www.google.com/search?client=safari&rls=en-gb&q=1%22+flanged+ball+valve&ie=UTF-8&oe=UTF-8
Register to Reply 8 comments
Anonymous Poster (2); babybear (2); maizi (1); PWSlack (1); RVZ717 (1); vidyadhar deodhar (1)
