Previous in Forum: Hydrostatic Testing of Tanks   Next in Forum: Oil Filtration
8 comments
Load Testing
07/15/2009 10:00 AM
I hope someone please tell me how to perform a load test for different lifting equipments like forklift trucks, mobile floor crane, trolley jack, etc...
Is there any standard that we need to follow?
Pathfinder Tags: load testing
Re: Load Testing
07/15/2009 10:02 AM
Contact the insurance company that provides lifting equipment indemnity insurance. Tests will need to be witnessed and carried out to the satisfaction of their engineer/surveyor, who will issue an inspection report as part of the insurance contract.
Re: Load Testing
07/15/2009 10:14 AM
thanks for your comment but I need a procedure or method to perform load testing on engine stands and lifting tools as well, for safety purposes only.
I have read about forklift and crane tests, but what about simpler tools like the ones mentioned above?
Re: Load Testing
07/15/2009 10:39 AM
If the equipment is certifiable lifting equipment, then the indemnity insurance company's engineer/surveyor can advise. In most cases, the test involves a controlled overload of the equipment that is witnessed and certified by that individual, after which the equipment can only be used to its labelled and certified safe working load.
Without indemnity insurance on certifiable lifting equipment, the operation must meet its own liabilities in the event of a catastrophic failure and additional penalties imposed at Civil Law can be high. In some jurisdictions, not having indemnity insurance for certifiable lifting equipment is also a criminal offence as well as foolhardy.
Re: Load Testing
07/15/2009 11:31 PM
Sorry for my ignorance, but certifiable lifting equipments are overhead and jib cranes, forklift trucks, and other motorized lifting tools?
But for turret and engine stands, pallet trucks, jacks, etc.. I don't think these have equipment have not been certified, nor insured in an unlikely event, well at least for the past 20 years but are still being used until now.
What do you think is a good procedure in load testing these uncertifiable equipment?
Re: Load Testing
07/23/2009 4:13 PM
hi PW,
That might be a good answer in UK, but in the US the insurance company stays out of it. It's up to P.E.'s to certify the equipment, and if that is done correctly, there is no liability to the company.
laby
Re: Load Testing
07/16/2009 12:00 AM
ok thanks
Re: Load Testing
07/15/2009 11:23 PM
There are many standards, one for each type of crane. Look at ANSI B30.XX. The short answer is that a load test should be annually performed with calibrated weights to no more than 125% of rated capacity, for a crane under ANSI B30.17. There should be no permanent deformation. Times, load sequence, deflection measurements all have their own parameters. If you are asking these questions, it may be best to hire an outside indepenedent contractor. Be prepared to pay.
I left software docs after too many years of writing fiction of varying degrees.
Re: Load Testing
07/16/2009 12:01 AM
ok thanks
Register to Reply 8 comments
joerol61 (4); Labyguy (1); mrhippo2 (1); PWSlack (2)
