Previous in Forum: Foriegn Particles in Hydraulic sysem   Next in Forum: Maintenance for pump and spare parts!
Air system
07/16/2009 12:56 AM
How to drain water from the air system
Re: Air system
07/16/2009 1:26 AM
And your question is?
Re: Air system
07/16/2009 3:29 AM
On the bottom of the bend on a saxophone
there is a valve that the player can use to remove moisture from it.
Re: Air system
07/16/2009 4:32 AM
http://www.spiraxsarco.com/ specialize in draining air and steam systems.
The above is their international site. You should be able to get onto the appropriate branch or agent from there.
They also have a lot of good info on what is needed for both air and steam trapping.
Good Answers: 101
Re: Air system
07/16/2009 5:42 AM
With an autodrain fitting.
Good Answers: 38
Re: Air system
07/16/2009 9:52 AM
First install a good dryer on the system and you should get very little moisture. For now check for a drain valve on the bowls where the water should be collecting and release the water. If there are none there should be an auto release valve that may be stuck. If neither are present, you have a problem. Install them!
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Air system
07/21/2009 3:46 AM
In order to have less moisture in the air system, the following shall be installed inthe system:
1. air dryer
2. auto-drain valve (electrically actuated valve)
3. moisture separator
You may consult the supplier for further information.
Anonymous Poster (2); charsley99 (1); DVader1000 (1); PWSlack (1); sceptic (1)
