G'day. Just a quick question (no brainer) regards long length of wires (~50cm long) that experience voltage fluctuations should I touch them with my hands. The intensity is increased if I ground my bare feet to the earth.
Brief overview:
The long wires are fed into the "+" and "-" pins of an Op-Amp. The wires are also fed with a 3-6VDC of low current (~100ma) with voltage fluctuation between the "+" and "-" pin of the Op-Amp acting as a signal for either high or low states.
Question:
To remove the interference caused by myself or adjacent wires and to prevent the wire acting like an "antenna", I have decided on using ceramic capacitors...although polypropylene is a current favourite thought. The caps will be mounted as close as possible to the Op-amp). Does anyone have any preferred method of filtering out surrounding interence on DC fed wires?
I have also considered grounded shielded wire or "twisted pairs" and will be used as a last resort. Cheers and thanks
