Previous in Forum: 7.5 KW Motor   Next in Forum: Transformer Vector Groups
Reactive power
07/20/2009 11:28 PM
how to increase or dcerase reactive power of generator?
Re: Reactive power
07/21/2009 3:11 AM
Start by explaining why there is a need, please.
Re: Reactive power
07/21/2009 4:23 PM
Reactive power is determined by the load unless we are discussing a generator which is operating in parallel with other generators.
If this is a parallel network, then the load determines the fixed reactive load and the excitation of the generators determine the distribution of the reactive load.
The reactive load can also be changed by adding capacitors or inductors to the circuit to tune out the reactance of the load.
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
