Previous in Forum: Check Valve   Next in Forum: Geothermal Heat Pumps
10 comments
air compressor
07/21/2009 11:06 AM
How can i improve the efficiency of my air compressor?
Re: air compressor
07/21/2009 1:46 PM
what type of compressor?
what PSI needed?
what are you using it for?
Re: air compressor
07/22/2009 10:26 AM
It is a reciprocating air compressor. It operates at about 6ksc.And i am using it as instrument air.
Re: air compressor
07/22/2009 10:28 AM
Reciprocating, 6 ksc and instrumentation devices.
Re: air compressor
07/22/2009 3:40 AM
Turn it off when the system is up to pressure?
Good Answers: 16
Re: air compressor
07/25/2009 7:59 AM
First check and verify the efficiency of the compressor, make any repairs needed to get it to the rated cfm. Ive got that calculation somewhere, let me know if you need it and I'll dig it up.
Be certain you have a good quality, proper functioning check valve on the discharge side. (preferably of the lift type, spring assisted) It should be close to the compressor, but far enough so the heat generated does not damage the valve if it has a soft material seat.
Keep your inlet filters clean and dry.
Adjust your cut in/out so the unit does not constantly cycle un-necessarily.
Repair any existing leaks in the system piping.
Re: air compressor
07/26/2009 2:23 AM
Thank u sir....it will be very useful to me if you give out the calculations
Good Answers: 16
Re: air compressor
07/26/2009 8:53 AM
The compressor must feed a receiver or tank of a known volume. (stamped tag)
To conduct the test, close the valve that isolates the receiver from the plant's distribution system and turn off the compressor. Vent the receiver down to approximately 30 psi and turn the compressor back on. Study the pressure gauge on the receiver and use the stopwatch to time how long it takes for the pressure to build from 50 to 100 psi. Use the following formula to calculate the flow (scfm) of your compressor:
0.45 VR t = OC
where:
VR is receiver volume, gal
t is time, minutes
OC is Compressor output, scfm
Dividing the results of the test by the manufacturer's flow specification will indicate what percentage of the original capacity the compressor is operating at.
As an example, lets say a 712-hp compressor has a factory rating of 28 scfm and an 80-gal receiver. It takes 2 min and 6 sec to build the pressure from 50 to 100 psi. Then:
0.45 80 2.1 = 17.1 scfm, and
17.1 28 = 0.61
So the compressor is operating at only 61% of its original capacity. This indicates that the compressor is operating at a severely diminished capacity. This information should be carefully considered before replacing the unit.
Here you go!
Re: air compressor
07/27/2009 12:15 PM
Sir, the information you gave will be of much use to me....But to my knowledge i have heard that the compressor rating will be like this....7 kg/cm^2 at 200m^3/min. Usually the free air delivered will be the suction volume. But in your example you have cited about the discharge volume which gives me a confusion. Could you please clarify on that.
Re: air compressor
07/16/2010 11:40 AM
Hello, I have an air compressor and i want to ad a holding tank for air. can i come out of the compressor with an air line and tee it, then put one line into the auxiliary tank and one line to my supply lines, or do i have to run and inlet and and outlet to and from the auxiliary tank.
Re: air compressor
05/07/2012 9:07 AM
Hey. I have a problem with my air compressor tank. It's not getting filled up properly. Can anyone help me ?
Register to Reply 10 comments
Anonymous Poster (3); balakailasaraj (3); MarkhamCornoit (1); PWSlack (1); Tim in Mexico (2)
