Previous in Forum: Steam Turbine Rotor Skew   Next in Forum: Fire Fighting Pumps
9 comments
Gaskets for O2 Line
07/22/2009 4:39 AM
What is the recommended thickness of the gasket and material for oxygen line of about 20bar pressure with temperature of about 140 deg c. Line size upto 200mm. I was thinking of using SS gasket with filler. But these are available with minimum thickness of 3 to 4.5mm. Normally thinner gaskets are used for gas lines, I remember.
Re: GASKETS FOR O2 LINE
07/22/2009 4:44 AM
What material is the pipework made from?
07/22/2009 4:56 AM
SS 316L
Re: Gaskets for O2 Line
07/27/2009 2:42 AM
My friend you have a very nice troubble. I suggest not to use flanges, as possible, try butt welds, and fast connections at the line end.
07/27/2009 11:26 PM
Yes All line joints are of BW. Only flanged valves and terminals require gaskets.
07/28/2009 2:51 AM
I would be inclined to use glass filed PTFE.
Thickness depends on the quality of the machining of your flanges.
07/28/2009 4:34 AM
I have finally decided to go for 1.6mm teflon gasket.
07/28/2009 6:53 AM
Suggest you use glass filled PTFE to reduce creep, especially at the temp you could be using.
07/28/2009 11:43 PM
what is this glass filled PTFE? Does not the powdered glass damage the PTFE in compression?
07/29/2009 4:16 AM
No but it reduces creep and significantly increases strength.
Register to Reply 9 comments
atorroja (1); b v rao (4); PWSlack (1); sceptic (3)
You might be interested in: Gaskets and Gasketing, Line-shaft Spools
