Previous in Forum: Black Sunrise Over India   Next in Forum: Shuttle and ISS Visible Tonight
Multiaxes Swash-Plate Angle in a Plunger Pump
07/23/2009 1:37 AM
I have seen a strange plunger pump. Normally swash-plate angle is about one axis (15~18 deg), but some have multiple axes such as 17 deg about x-axis and 2 deg about y-axis. I have heard that the pump is used in aerospace. Does anybody know the reason of multiaxes angle?
Good Answers: 119
Re: Multiaxes Swash-Plate Angle in a Plunger Pump
07/24/2009 8:52 AM
Probably to provide clearance from adjacent components and structure, and/or provide a more conducive route for hoses/wiring and maintenance access.
Gearboxes on aircraft turbine engines are amazing crowded with components and must fit in incredibly tight spaces. A degree or two can make a big difference in getting wrench access to service the unit.
Seeing the installed pump would probably answer your question immediately.
Hooker
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
07/24/2009 8:45 PM
Hi Hooker
I think the OP was saying that the swash plate had two axis of adjustment NOT the pump casing! It seems strange to me and I've seen a lot of swash plate pumps!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
