Previous in Forum: Vapour Absorption Refrigeration System   Next in Forum: Calculations for Scissor Lift
10 comments
mechanical engineer
07/25/2009 10:47 AM
what is torque
Re: mechanical engineer
07/25/2009 10:53 AM
torque is force multiply by distance
in mechanical engineering, it is called "moment"
KIRAN G
01/02/2013 4:34 AM
Dear Mr. kiran001,
NOT NECESSARILY. TORQUE results in angular movement "force multiply by distance" is known as BENDING MOMENT.
DHAYANANDHAN.S
07/25/2009 11:52 AM
Torque is a twisting force, if applied axially at end of the bar, it will cause torsional stress.
Source: http://www.mathalino.com/reviewer/mechanics-and-strength-of-materials/torsion
07/25/2009 10:19 PM
"Torque is a measure of how much a force acting on an object causes that object to rotate. The object rotates about an axis, which we will call the pivot point, and will label 'O'. We will call the force 'F'. The distance from the pivot point to the point where the force acts is called the moment arm, and is denoted by 'r'. Note that this distance, 'r', is also a vector, and points from the axis of rotation to the point where the force acts. (Refer to Figure 1 for a pictorial representation of these definitions.)"
Damn, I can't find Figure 1.
07/25/2009 11:12 PM
Torque is equal to the Moment Force Multiplied by the distance based on axial forces produced about a shaft which causes rotational twistng or torsion.
When talking in terms of rotation of a shaft we call it torque.
When talking for example about a hinge door rotation its simply the Moment (force)
Roderick Whitfield
Good Answers: 53
07/26/2009 8:02 AM
I remember my school time when my teacher did twisted my arm badly.
07/27/2009 4:30 AM
Ouch! Was the lesson about torque well-learned?
Good Answers: 53
07/27/2009 8:42 AM
Yes that happened when I asked how to measure torque, and she told more the pain more is torque.
01/02/2013 4:31 AM
Dear Mr. Rakesh,
It appears more practical class than teaching.
DHAYANANDHAN.S
07/27/2009 4:32 AM
It is a topic for reading within encyclopediae.
Anonymous Poster (1); dhayanandhan (2); kiran001 (1); lyn (1); PWSlack (2); rakesh_semwal (2); RTFVerterra (1)
