I have designed a backgague control system for a gillitione with a screw with 10mm Pitch, and use 100 pp/rpm encoder. This works fine.
But now i have been asked to supply a controller for a backgague with 3/16 inch pitch. This does not work for me, or for my controller because we dont have a floating point or double interger facility. Our interger file only allows us the create a maximum value or 32766. Our encoder is 100 Pulse/Rpm and we use this in a high speed mode x 2 (to enable count up and down). The problem is that we require accuraccy over the whole travel 700mm, so i dont think we can multiply then divide the value to acheive the target, either way i am dammed.
IE: We look at things 200 Pulses/Rpm = 4.76mm
The thing about this is thinking outside the square, i belive it is possible, it is just the way that my programme has been created. I have developed the software by calculating distance to be traveled by pulses per 1/10mm (we do require this accuracy).
I cant put my finger on it, but i think there is another way, we still have to set the distance per reveloution, for the machine setup or do we do things another way?
Got any Idears?
