Previous in Forum: Thermosetting Polymers for Printing   Next in Forum: Active Thermitic Material Discovered in Dust from 9/11 at World Trade Center
Flow Rate of CH4
07/27/2009 4:35 PM
Hello,
I have a gas tank of CH4 with a 0-50 psi pressure regulator. I am injecting the methane in the air intake of a diesel engine. The piping taking it to the piping is 1/4" of diameter and 2m long. The density of methane is 0.68 kg/m³.
I need to send to the engine a 40 L/min flow of methane. Is the pressure of 50 psi sufficient to get this flow?
Thank you
Re: Flow rate of CH4
07/27/2009 5:10 PM
This sounds like a homework problem that's out of my field. So these questions and comments may be only a red herring but here goes.
  • Do you intend on using the 2 meter long 1/4" ID diameter hose as the flow limiting orifice?
  • Will this flow enter the air-stream before or after the throttle?
  • If your diesel has a turbo will this be before or after the turbo
  • For your safety and to conserve methane find a way to turn off this flow if the engine is not running. Administrative control (remembering to manually turn it off) will not be sufficient to be really safe.
07/28/2009 9:57 AM
yes
the methane will be injected directly into the air intake of the engine
there is no turbo
I am using some check valves and needle valves for this
thank you, I got the answers I wanted from the other thread linked here.
Re: Flow Rate of CH4
07/28/2009 3:28 AM
Use the Weisbach Darcy equation for generalised pipe flow, as suggested in the earlier thread on this topic. If the answer is greater than 50psi, use bigger diameter pipe.
07/28/2009 3:54 AM
07/28/2009 9:30 AM
Nice work on the other thread PWSlack. Another GA for you. Also, I seem to have guessed correctly myself, I had no answer but at least my questions were right.
markmai86 (1); PWSlack (2); redfred (2)
