Previous in Forum: Gen Set Power Consumption   Next in Forum: 18-VDC Power Supply
Coal and Salt in Earthing
07/28/2009 2:58 AM
Hey, Would you please like to share some information, about the role of Coal & Salt in the electricl earth pits. What are the specifications of these materials while fabricating a pit. The Check point for the performance of earth pit.
Good luck & Take care
Re: Electrical Earth Pits
07/28/2009 3:33 AM
Seawater is an excellent material for irrigating the immediate area of an earth pit so as to reduce earth loop impedance. In the absence of seawater, any other conductive fluid will do. Animal urine is one possibility.
Re: Coal and Salt in Earthing
07/29/2009 1:44 AM
Earthing/grounding and your name...what are you earthing building, machine, lots of machine, building grid, or lightning rod (or rods)...how much rainfall do you get, how deep is groundwater
How big is your pit? and especially how deep? Does it reach groundwater??
Specifications difficult to come by BUT if you are in a dry climate, groundwater is deep (>20m), and you have lots of sandy or limestone or sandstone you may need a shaft of about 200mm diameter down to the groundwater table backfilled with fine coal, coke, charcoal, or any other cheap conductor, yeh add some salt (5-10% by volume) to improve conductivity AND add a trickle of water (from any AC or other persistant sources of water)...salt water is OK BUT keep it DAMP ALWAYS.
TOM
07/29/2009 2:34 AM
Charcoal is porous and absorbs the salt water. It tends to keep the surrounding area conductive. In India there is a national code for earth pits that specifies the resistance of the earth pit as 4 ohms, if I remember right.
bioramani
bioramani
07/29/2009 3:51 PM
The property of charcoal that is useful in this particular case is its conductivity, not its adsorbency.
07/30/2009 1:04 AM
In India charcoal is made in the traditional manner at a low temperature without graphitiization. This significantly increases the electrical resitivity. There is a sharp drop in reistivity of charcoal burnt at a high temperature especially ifcatalyzed with aluminum compounds.
Bioramani
bioramani
Anonymous Poster (1); bioramani (2); ctwiliams (1); PWSlack (1)
You might be interested in: Mining Tools, Flame Photometers, Softeners
