Previous in Forum: Ferro Magnetic Materials   Next in Forum: Coil Cleaner for AHU / AC
11 comments
Engineering Fields - Manufacturing Engineering - New Member United States - Member - New Member Popular Science - Cosmology - New Member
Mica Sheets
07/28/2009 9:04 AM
I am in the process of trying to source Mica sheets cut to size. .195" (50MM) thick and cut to 14.75" x 20.75".
Anyone know of a manufacturer of mica products such as this?
Regards, and stay Positive
Re: Mica Sheets
07/28/2009 9:13 AM
There's a factor of 10 adrift somewhere:
  • 50mm = 1.97"
  • 0.195" = 4.95mm.
Which is it?
Re: Mica Sheets
07/28/2009 9:53 AM
I meant 5MM then sorry, It is very thin for Mica.
Re: Mica Sheets
07/29/2009 2:09 AM
No, it is not very thin for mica, but on the CONTRARY is is EXTREMELY THICK for MICA. Could you please explain the application / end use. Please advise size that is the length & width or alternatively the diameter. If it is in the long form what kinds of ends do you want - rectangular or half round [full - radiussed / elliptical / obround] Best Regards Rasesh Vakil DURA HART GLASS & MICA WERKE 321, "PIONEER" INDUSTRIAL ESTATE, SUBHASH ROAD, JOGESHWARI [EAST], MUMBAI : 400060. INDIA TELEFAX : +91-[0]22-28264704 / 28240298 CELL PHONE : +91[0]9324246431 / 9820066171 email id : durahart@vsnl.net raseshvakil@yahoo.com
Re: Mica Sheets
07/29/2009 9:21 AM
Once again I must apologize;
I was hasty in my initial posting, on size. The thickness is (.0195") or (.50mm) The material is a flat sheet that we use as a barrier between an active electrical heating element. It is 20.75" wide and 14.75" tall. We use this heater as a personal use heater usually put under a desk while working. Sorry for the confusion, and thank you for the replies and help
Re: Mica Sheets
07/30/2009 1:00 AM
You would then need a heating element in between 2 pieces of Mica and joined together.
Re: Mica Sheets
07/28/2009 10:46 AM
Thank you for the link.
Good Answers: 53
Re: Mica Sheets
07/28/2009 11:15 AM
Loaction?
Re: Mica Sheets
07/28/2009 1:48 PM
USA Indiana.
Good Answers: 53
Re: Mica Sheets
07/29/2009 5:09 AM
Re: Mica Sheets
03/01/2011 3:45 PM
Thank you very much
Register to Reply 11 comments
Anonymous Poster (1); PWSlack (1); rakesh_semwal (2); raseshvakil (2); rwindbigler (5)
