Previous in Forum: Radical Technological Shifts   Next in Forum: Millwright
separate water
07/29/2009 8:59 AM
can you separate water from LPG by freezing it and which method use to ?
Re: separate water
07/29/2009 9:50 AM
What are the starting conditions?
What are the intended conditions?
Good Answers: 53
Re: separate water
07/29/2009 10:10 AM
So you have decided to take risk?
Re: separate water
07/29/2009 11:16 AM
The forum needs these parameters in order to advise, and whichever username asks the questions is irrelevant.
Given the anonymity of the forum, users behind the usernames cannot be liable in the event of an unscheduled catastrophic economic event happening to any original post-holder.
Re: separate water
08/07/2009 7:16 AM
starting cond: pressure 8 - 10 barg., 15 degree C, water content around %1 max. in liquid phase LPG, transfer velocity 2 m/sec. volume up to 10 tons/h.
intended cond: less than % 0.01 water content.
Good Answers: 19
Re: separate water
07/30/2009 11:08 AM
if you burn the LPG stored in a pressurised tank the tank will get cool and water will condense on its surface, collect that, when the LPG burns there will be a very high water vapour content, if you can feed this through the right type of exhaust system you can collect the water as it condenses, in between these two points you can do useful work with the heat, such as running an internal combustion engine to drive / power something. Because of the condensor required in the exhaust this will limit you to a stationary application.
Good Answers: 53
Re: separate water
07/31/2009 1:54 AM
Hi,
Are we trying to get water from LPG?what will He do of the water retrieved from mixture?
Re: separate water
08/07/2009 7:24 AM
dear, I mean to take off the water contamination from the liquid LPG.
Anonymous Poster (2); HUX (1); PWSlack (2); rakesh_semwal (2)
