I have recently had a rash of fan shaft failures. The shaft is wearing out under the inner race of the bearing causing the failure. The weird part is the bearing is still fine. This fan is vertical and it doesn't matter which beearing goes top or bottom. This is not isolated to one unit only we have approx 43 units and have had about 6 failures in the last 8 months. The drive for this unit can be either v-belt or gates poly chain but it doesn't seem to matter. The inner race has also been drilled to avoid inner race slippage on the shaft. any thoughts. Thanks any thoughts call me 250-789-2217
