Previous in Forum: Appliances With Personal 'Onboard' Power Supplies   Next in Forum: Thermoforming Process
Hydraulic Systems
07/29/2009 1:19 PM
i have been challenged to design a manually operated hydraulic brick making machine. you and i know that a power pack is needed for most hdraulic machines. the puzzle is on how to manually drive the cylinders whilst mantaining a high efficiency. the principal of a hydralic jack is very slow and inefficient, so dont even think about it. can someone help me on this design.is it possible?
Re: Hydraulic Systems
07/29/2009 1:28 PM
Hydraulics packs a lot of power into a small area. Humans pack a lot of area into a small amount of power.
Brick making is a a high volume production operation typically. Human power in not efficient or practical for much average energy output. You will be best off finding a better power source to run your equipment.
Unless you can get slave laborers in large numbers to run on tread mills to power the hydraulic pumps!
Good Answers: 101
07/29/2009 1:33 PM
Send me a message. I design Hydraulic/Pneumatic/Motion control/Automation systems for a living, and my company just so happens to give our engineering away for free, with the hopes you buy the parts and pieces from us.
I would be glad to go over the system with you.
Good Answers: 15
07/29/2009 3:30 PM
How many bricks are you planning on making in an hour? 1, 10, 100, 1000, 10,000.
Is this is a "3rd world" application? or ?
downhill slide to 112 (damn memor.)
07/30/2009 1:26 AM
http://www.deatech.com/pipermail/coblist/1998/001248.html
http://www.strawbalecentral.com/cinva/ram.html
http://home-and-garden.webshots.com/album/554821591zLVdzd
bioramani
bioramani
Good Answers: 204
07/30/2009 10:04 AM
Gift71,
you have not provided us with enough information to be helpful. Please write more specific requirements and parameters. (especially what is meant by "Manual"?)
Chris
Good Answers: 213
07/30/2009 10:27 AM
Begin by looking at "Compressed Earth Block" on the web- specifically the Cinva Ram developed in Colombia in the 1950's. This will not give you the design you are after, but will give you the basic requirements for your system.
Register to Reply 6 comments
bioramani (1); chrisg288 (1); cwarner7_11 (1); ddk (1); RVZ717 (1); tcmtech (1)
