Previous in Forum: Hydraulic Systems   Next in Forum: Restoring an Antique Barber Chair: The End is Near (I Hope)
Thermoforming Process
07/29/2009 3:20 PM
Can somebody tell me about thermoforming process if I want to start from scratch and build parts? Which machine is the best to use and what is its limitation? What is the limitation in thermoforming process?
Re: Thermoforming Process
07/30/2009 7:12 PM
well there are a few I'm familiar with . brown , Lyle ,macc . and most likely more. as far as limitations it really depends what your trying to produce
Let your conscience be your guide.
07/31/2009 3:46 AM
Hi
First tell me about the thickness of the material sheet which you want to make.
Thnaks
Ramesh Vabanagiri
07/31/2009 11:51 AM
what do you want to produce ? what is the maximum dimensions of the piece? what is thickness of sheet or else are you starting from? what production rate do you require ? do you have a good supply of electricity ? if not gas or other fuel ? with this date probably i can help.
08/28/2009 2:22 PM
Im interested also in buying a thermoform machine. does anyone know vendors of these equipment? or does anyone have equipment no more than 1 year of use that want to sell?
Open your eyes, look within. Are you satisfied with the life you're living?
08/29/2009 6:59 AM
there are several types of thermo forming machines for various applications . What do you want to manufacture ? and in what quantities ?
angelo (2); Anonymous Poster (1); Manufacturing Jedi (1); mrhemightdo (1)
