Dear Sir,
We are using multiple conductors ( 8X300sqmm) to connect our main supply to the MSB (3 phase). These cables are supposed to be laying in PVC conduits. I would like to know the recommended practice we should follow when we using multiple phase conductors.
A) Is it advisable to use single PVC conduct to run all the same phase cable? will it create any eddy current problem or something else.
B) Or we have to run all phase cables, Neutral + Ground in each PVC conduct (3 phase cables, Neutral + Ground)?
Your early response would be highly appreciated.
Regards,
Asitha
