Previous in Forum: HYDRAULICS   Next in Forum: Safety Factor
Pulleys and Linear Travel Calculation
07/30/2009 11:39 AM
How can you calculate the mechanical advantage (linear) gained thru pulleys?
I have a cylinder ... stroke is 126" (10'-6") and I need to move an object aprox. 24'.
Is there a formula available? Any help would be appreciated. Thanx.
Cadguy
You've got your story ... and I've got the truth! (Kurt Russell - aka Cash - Tango & Cash)
Re: Pulleys & Linear Travel Calculation
07/30/2009 11:43 AM
This link gives the basics of pulley operation.
07/30/2009 11:57 AM
Thanx JohnDG. I had seen that site B4. The mech. advantage of pulleys is always focused on forces, but is that also applicable to linear as well? In other words if you have a pulley system that provides a MA of 2 or 3, is the distance moved 2 or 3 times as well?
Cadguy
07/30/2009 12:38 PM
If it creates a MA of 2 or 3. The distance would be approx. 1/2 to 1/3 respectively
07/30/2009 6:31 PM
As phoenix911 indicated, the positional and mechanical advantages are inversely proportional.
The only place this is (obscurely) referred to in the post I gave was right at the end, where it says something like " ... since W = FD".
This means "Work done = Force x Distance moved".
Re: Pulleys and Linear Travel Calculation
07/30/2009 2:37 PM
You wish to move an object 24' with a ram that extends 10' 6" ... so object moves 2.3 times the stroke length?
Why use a pulley system and indeed can you?
Regards Woody
07/30/2009 2:58 PM
Yes Woody
Using a hyd cyl to winch a container on a truck. New venture but has been done many times by different means ... all with pulleys (sheaves).
Register to Reply 6 comments
Cadguy (2); JohnDG (2); phoenix911 (1); woodygb (1)
