Previous in Forum: AC Controlled-Current Stimulator   Next in Forum: Achieving High Motor Power
9 comments
Help with Inductive Proximity Sensor
07/30/2009 3:53 PM
We are trying to build an Inductive Proximity Sensor for metal wheels. This will mount to a metal wheel and give an output when the wheel passes over the sensor. We currently use a traffic detector for this with a 6" diameter 250uH loop. The wheel is a large amount of ferrous steel about 4-6 inches away from the loop. I would like to redesign the traffic detector amplifier component so that it can be integrated into the loop. The biggest issue with this design is that it needs to run 24/7 and be able to handle temperature changes.
I have considered using a PIC with an oscillator output and then monitoring the frequency shift for detection. Does anyone have any suggestions of an easier way or a good PIC to use?
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
Re: Help with Inductive Proximity Sensor
07/30/2009 4:38 PM
Have you thought about using a crank position sensor from a automobile. Sounds similar to what the one on a GM vehicle does. It handles temperatures from below zero to 250 - 300 degrees I believe.
If necessity is the mother of invention then is laziness the mother of necessity?
07/30/2009 5:11 PM
07/30/2009 5:26 PM
These are good ideas, but we need a pattern on this of slightly larger than what they provide. I have not looked at the Hall effect sensors at all. I actually think our loop works well, but we need something new to drive it.
07/30/2009 6:00 PM
There are a number of hits when you Google inductive proximity sensor
07/30/2009 11:06 PM
07/31/2009 12:45 AM
The best sensors I have found for this are from a company called Proxitron (www.proxitron.com). Because of the metal wheels, it sounds like you are using this with some type of rail system. I have specified the large "hockey puck" style inductive sensors into this type of application and they work from -30F to 180F without any problems. You can get roughly 4" (100mm) away from the target with some of the larger units.
07/31/2009 7:01 AM
Over what sort of distance do you need to detect the wheel?
A simple metal detector circuit (many on the web) will detect iron and steel easily so long as the distance does not exceed the diameter of the search coil, so if you build a 25cm coil, it will clearly detect a wheel at 25cm distance (probably more, but for reliability stay with that)......
Make a coil with a diameter slightly more than the maximum detection distance.....Pulse induction type circuits are a good place to start with.....
PICAXE PICs are probably the easiest/cheapest to program and use, All software that you need is free..... Check out their website at:-
Picaxe PICs
07/31/2009 9:18 AM
This will be used to detect a train wheel rolling over a point on the rail. None of the sensors mentioned meet the requirements. I want to design a frequency shift detector for this application. I think this will provide the best results. These sensors are also subjected to things that will require them to be smart enough to "retune" when they are subjected to a change over time.
07/31/2009 11:00 AM
There are many details I don't know about this application, but it seems to me that a simple PZT accelerometer would easily detect a train wheel passing over it. This would produce a huge spike in the accel's output. A simple rectifier would provide a DC output, and a threshold detector could provide a positive "wheel found" criterion.
PZT has a wide temperature range, and protection from water should be easy to figure out.
Register to Reply 9 comments
andrewvanh (2); Andy Germany (1); Anonymous Poster (1); double_j_b (1); lyn (1); Sensor Guy (1); wareagle (1); WoodwardDL (1)
You might be interested in: Inductive Couplings, Hook and Loop Fasteners
