Previous in Forum: Internet Explorer 7   Next in Forum: Mobile Phones Memory
Inventor Weight Calculator?
12/11/2006 12:18 PM
Hi,
I use Inventor 9 and I was wondering if there is a way for the software to do two things. First, Can it calculate the actual or approx. weight of an assembly? Two, I use it mainly for furniture design and I wanted to know if I could somehow set it up to help me figure out approx. board feet of material or number of sheets of material etc.?
If someone know how this might be possible, can you give me an explanation or direct me to a good source for the answer.
Thanks
Re: Inventor Weight Calculator?
12/12/2006 4:54 AM
I'm using a later version of Inventor but I'm fairly sure that this is the same as v9. If you model a part then use 'File, Properties, Physical' to choose the correct material then use 'Tools, Update Mass Properties', Inventor will know the mass of the part. Going back to 'File, Properties, Physical' will show you the mass. As you build an assembly Inventor will keep track of the combined mass & show it in 'File, Properties, Physical'.
Reply to Forum Thread
