Previous in Forum: Transformer Test Results and the Expected Values   Next in Forum: Load-Sharing Methods in Generator Synchronization
Neutral Contactor in Synchronized Gensets
08/01/2009 11:25 AM
Why do we need neutral contactors for each generators in a group of generators (synchronized generators)? What problem could happen if we connect all the neutrals directly with the ground?
Re: Neutral Contactor in Synchronized Gensets
08/01/2009 12:20 PM
I do not think you need any contactors. The neutrals should all be connected to the neutral bus.
Good Answers: 244
08/01/2009 7:24 PM
Is your system's neutral grounded through NGR (Neutral Grounding Resistor)?
If yes, then only one generator need to be grounded at a time (see the previous posting http://cr4.globalspec.com/thread/36055 ). This could be the reason of separate neutral grounding contactor for each generator.
-MS
08/03/2009 11:55 AM
there is no ngr we are installing a new gensets
06/27/2024 10:01 AM
  • The best source of information is the Designer, whose name will be on the "for construction" drawings.
  • If the system is already built, then the name will be on the "as built" drawings.
  • If it is on neither of these, the original equipment manufacturer's contact details will be on the outside of the equipment.
  • If it isn't there then it will be in the maintenance information for the facility.
It is extremely unlikely that these sources of information are registered as users on CR4.
Register to Reply 4 comments
msamad (1); nebiyou (1); PWSlack (1); wareagle (1)
