Previous in Forum: Capacitance Calculations   Next in Forum: Required Lux
Technical Fields - Technical Writing - New Member Engineering Fields - Environmental Engineering - New Member
Location: The 'Hub of the South Pacific'; 18.15°S, 178.45°E
Inverter Current
08/04/2009 12:31 AM
Greetings CR4'ers,
If I have an 800W, 12Vdc to 240Vac, power inverter hooked up to a 105Ah deep cycle (12V) battery, how will the current (dc) drawn by the inverter (from the battery) vary with increasing ac loads (from the usual home appliances)? Can I measure this variation by simply series-connecting an ammeter between the positive terminal of the battery and the red (positive) cable of the inverter?
VT
Re: Inverter current
08/04/2009 3:25 AM
Yes, that would do it. It should be linear, and almost proportional.
Expect the internal circuitry of the inverter to shut the thing down if the aggregate of the connected AC loads exceeds 800W.
Re: Inverter Current
08/04/2009 2:12 PM
DC power in = AC power out + 10%.
08/17/2009 3:06 AM
do you have any reference for this equation
08/19/2009 11:54 AM
A really well designed one may get to over 80%, but I simply cannot believe 90%, sorry!
A bought (cheap?) one will probably be 60% efficient at best......
Hobbies - Fishing -
08/19/2009 9:14 PM
The Outback inverters I install are rated at 96% at full output. The key is "full output". Efficiency drops as the load does.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
08/20/2009 2:20 PM
Excellent point (I did not dream that even that was possible, thanks for the info).....But take an average for a small user and what do you get? Lets say 70% on average? and that would be excellent......
Have a great day.
08/05/2009 1:15 AM
Losses in the inverter are
(a) Fixed loss, which includes power consumed by the control circuit and MORE IMPORTANT the standby current & therefore power "consumed" by transformer & filter choke ( if any ). I presume the inverter is not high frequency switching type, rather a more conventional one using 50/60 Hz power transformer.
(b) Variable loss, which is the power loss in the power circuit ( IGBTs, MOSFETs. etc.) and copper loss in the transformer & a very marginal increase in the magnetising current of transformer.
Thus the current drawn from battery will not be directly proportional.
Thanks and regards
Ashok Toshniwal, Bangalore, India
Register to Reply 7 comments
Andy Germany (2); ashoktoshniwal (1); eng.hmk (1); lighthasmass (1); Nah (1); PWSlack (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
