Previous in Forum: Demineralization   Next in Forum: What's the Best Coating for NPK Fertilizer?
Fertilizers and Vibrating Screen Capacity
08/05/2009 12:12 AM
Hello everybody, I am a Process Engineer in a fertilizer plant in Indonesia. I have a Screen for separate the fertilizer granuls sizes into onsize and offsize. The case is, now my production capacity is higher than design capacity,so Screen can not handle all product. So, WHAT CAN I DO TO INCREASE CAPACITY OF MY SCREEN?? thanks alot for yours attention, so i'm waiting the answer from yours as soon as possible. best regard ivan
Re: How can I do for increasing Vibrating Screen Capacity?
08/05/2009 3:27 AM
Here are some possibilities:
  • Grind the oversize material smaller before it arrives on the screen
  • Increase the area of the screen.
08/05/2009 9:25 PM
Thanks alot Mr.PWSlack Now, my plant produce 100 MT/h fertilizer (The design is 60 MT/h), so i use bypass to transfer 50% product to next device and use screen for 50% product too. The effect is the undersize through with the product together.
08/11/2009 9:04 AM
It sounds as though the problem has been resolved, then. Well done.
Re: Fertilizers and Vibrating Screen Capacity
09/03/2009 2:02 PM
Mr.Iwan,
U said that, u r production capacity is incresed more than 40%. we are having some other options to increase the production through the screens.
Hope u may be in the plant of complex fertilizer or Urea.
So first plz find the design angle of u r screen. this is one of the important parameter to increase the load. where this is totally depends on bed hight of the material.
If u need further details of how to improve the loading of screens plz scrap me out.
Karthik
09/04/2009 2:14 AM
Mr. Spic Karthik 1. thanks alot 2. i am in the plant of complex fertilizer. 3. finally, i choosed replace that screen with the bigger screen (160 MT/h).
09/04/2009 9:48 AM
Mr. Iwan,
Am also process Engineer in fertilizer unit.
If u suppose increase the angle of screen means, the residential time for the material will get reduce. To meet over this residential time less, u can improve the vibration in the screen.
This will increase Ur capacity.
but this will support in some extent.
Karthik
Register to Reply 6 comments
iwan_rbg02 (2); PWSlack (2); SPIC KARTHIK (2)
