Previous in Forum: Tsugami Thread Roll Machine A5D   Next in Forum: Hydrotest Failure
Bolts for Motor Operated Valves (MOV)
08/05/2009 6:47 AM
All,
Through Bolt vs Normal Bolts on both sides of valve. This is regarding MOV.
Whether all wafer type Motor Operated Valves (MOV) require through bolt option.
Thanks
Be simple and specific for a great success in Life
Re: Through Bolt vs Normal Bolts on both sides of valve
08/05/2009 6:52 AM
As some wafer valves are supported between flanges, the answer is 'no'.
08/06/2009 3:36 AM
As you said some wafer type MOV needs normal bolts on both sides of valve. Can you please send details so that one can distinguish?
All wafer type MOV do not require through bolts is Project specific statement or a Standard statement?
Thanks
08/06/2009 3:45 AM
Register to Reply 3 comments
You might be interested in: Bolts, Bolt Tensioners, Anchors
