Previous in Forum: Cell Phone Etiquette   Next in Forum: RS232-RS485 Converter
Coaxial Cable Interferes with RCA Signal
08/10/2009 1:06 AM
Hello,
The Set up:
I use my computer to watch videos on the tv. I use a Nvidia Fx 5500 video card that uses a S-video exit. I have a cable with a S-video end (for the card) and on the other end it has a yellow rca video connector connected to my tv video input. The tv receives channel signals from the optimum company through a coaxial input (My tv is analog).
The problem:
Every time I want to watch video from the computer I connect the rca yellow video cable, but ever since i moved to this new place there is this interference on the tv that goes away when i unscrew the coaxial cable. The interference is kind of side to side in the tv, you can still see the image from the computer though. I also notice that when i connect my other computer with the same set up the interference is less.
I have tried:
the coaxial cable that goes to the tv was too short, so we had to couple it with another six feet coaxial cable. I bought a week ago a better cable to couple it with and i still have the same problem.
The company was called and they said that i should buy a KVM switch; that their signal wasn't the problem, but i don't think the set up will help will help because i would still have the coaxial cable connected to the tv and this is the one that is making the interference.
Any help will be appreciated, Thank you
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
Re: Coaxial Cable Interferes with RCA Signal
08/10/2009 9:24 PM
I am not giving an answer here. Just my thoughts. I am surprised to hear you are sending an S-Video signal to an RCA jack with no electronic converter/filter and even with no seperator switch to isolate co-axial connection from RCA?
CraziestOzzy
08/10/2009 9:45 PM
hi,
i did it that way before. from S to rca video (to hook up the computer with the tv-so the tv is just another monitor) and the tv has its own coaxial input to get the channel.
Why are you surprise? is it wrong?
Good Answers: 12
08/10/2009 10:03 PM
...no, not implying anything wrong. My setup at home has allways had RCA connecting to RCA, S-Video to S-Video. It is my uneducated reasoning that to use a multiple signal S-Video connection without any conversion/filtering prior to being sent to a single RCA jack connection is prone to interferance or impure signal output at the RCA end.
I have allways had the TV run in AV mode when using a computer to transmit video signal (RCA or VGA in my case) and used the TV mode for coaxial and have no interferance. Your six foot length of cable is well under any limits I know and not in my view an issue. Neither cable connected to TV set needs to be switched or disconnected if I wish to change view from either coaxial (TV) or RCA (computer).
I perhaps would run a continuity test with a multimeter to see if there is any leakage or damage from the cables and connectors you are using and perhaps chuck a ferrite filter over both extreme ends of cables.
...forgot to mention, you may need a mechanical switch to isolate the RCA and the coaxial from each other (and switch to either cable depending on what source you want to watch video from) as the TV set may have a stuffed filter itself.
CraziestOzzy
08/11/2009 12:37 AM
No active conversion required to change S-Video to composite.
Sounds like you have some type of ground loop situation. You might want to check your electrical grounds to be sure they are proper. About the only other solution would likely be isolation which is probably best accomplished by switching the coax off the TV though a regular switch is not likely to switch the ground circuit so that probably wont help. If you have a 300 ohm input on the TV you might use a balanced to unbalanced conversion transformer or maybe put to together back to back (connect the 300 ohm sides together) to effect ground isolation.
Good Answers: 68
08/11/2009 12:44 AM
Hello Guest,
Do you get your connection from a shared antenna like you get in flats? Or are you getting a direct antenna supply from Sky or Cable? It sounds to me like one of the sockets or plugs (male or female parts) of the antenna and or the link piece you put in to make it long enough. This, if a single connector is not wired correctly can screw your signal up.
Good luck.
08/11/2009 8:34 AM
Check the video card signal because it may not be a S-video out. New Video cards use the same card end connection for digital outputs YgYpYb
Good Answers: 18
08/11/2009 11:11 AM
For the CR4'ers: Just an EWAG here, but it may well be that he is using a cable specifically made for the purpose, that would be similar to these S-to-RCA adapters.
The S-Video circuitry in your video card separates the Luminance (pin #3) from the Chrominance (pin #4) and provides each signal separately. The other two standard pins (#1 & #2) are ground references for the others, and may be joined directly and soldered to the RCA outer bonding shell. If your card has additional pins, they are only for specific uses by that manufacturer, and should not affect use of the standard ones for video only.
The Lumi has a wide range from low to mid frequencies compatible directly with the composite input of your TV, but the Chrominance includes much higher frequency information that must be - equalized (for lack of better specific term) - before joining them together. Various references indicate preference for different "types" of capacitors depending on the form factor of the adapter, or additional circuitry if the signal is going to be reversible, but basically it's nothing more than a 470pF cap in the Chroma #4 lead, prior to #3 & #4 being joined to the center post of the RCA.
Now, knowing this, you still may have a need to ensure everything is properly grounded/bonded, as it "may" be that something came loose in your move to this new location.
But my guess is an impedance mismatch or straight out interference on your new Cable service coax.
Composite Video signals, whether transmitted through a poor old RCA cable or a nice RG-49 Coax, all want to transmit their way "into" the TV at the same 75 Ohm impedance as the TV circuitry, otherwise things get ugly quickly. *That's one of the biggest motivators for moving to digital.
RCA plugs and format are the worst because they not only use tiny stranded conductors that break more easily, but the plug connectors and the format itself is not capable of correctly "matching" 75-Ohm impedance. It was invented simply as a secure way to get an analog audio signal from a gramaphone over to a coupled horn. And here we're trying to use that connector to display Halo from a PC. Go figure.
A loose shield or connection in your new location behind the wall with your cable, interference on the shielding of your cable company incoming service, high voltage inductance or other AC voltage getting to your power supply ground, poor extension coax cabling, or damage to your S-Video-to-RCA adapter cable, could all cause some leakage of signal or a change in impedance.
Recommendations
#1) Eliminate any "extension" multiple cabling on your coax, by simply getting a cable that is long enough in the first place.
#2) Also, there should never be a cable company cable that just pokes-through-the-wall to screw directly into the TV. Make them do it right, by terminating the cable inside a back-box with a coverplate that gives you a wall jack. Gold-plated or not, that's the correct installation method to reduce other issues.
#3) If you have a separate adapter at the end of your S-Video cable, try replacing that cable to ensure no damage there is contributing.
#4) Have the service tech for your new cable company to do a ground check, to ensure the outside cable demark has the shield correctly bonded directly to your power utility grounding rod conductor, and do a noise/interference check on your coax. You don't even need to go into the computer video-card used on the RCA input issue, just tell them you get some interference and want it checked out.
They may be able to check your receptacle ground and neutral lines for noise as well, but you can use a multimeter to make sure there is no AC voltage between the ground plug and the neutral. If so, get the landlord to have his electrician out immediately. I say neutral-noise, because a loose neutral connection or improperly bonded or 'shared' neutral causes some strange behavior with electronics, and your TV likely has no ground, just a bladed plug for line and neutral. The computer, on the other hand, is 3-prong grounded as well, which is then the 'reference' for any signals paired with bonded 'ground' lines or shields, so that side should be good.
If you ever decide you want to purchase good cables, I don't want to make this sound like a referral as I have no relationship whatsoever with this company, but I have never had a problem with the engineered materials, construction, quality or value from this supplier: Blue Jean Cables
Though I despise Wikipedia's bias and censorship in many areas, technical articles tend to go unnoticed by the activists, so you may wish to familiarize yourself with the various portions of video signal issues:
Here S-Video
Here RCA Connectors
Here COAX F-Connector
Here Coax Cable
and Here Interference
Call it 'half empty' or 'half full' if you must, I've got the other half in a redundant glass...
Anonymous Poster (2); babybear (1); CraziestOzzy (2); rcapper (1); Sandman (1)
