Previous in Forum: What's This Thing Called?   Next in Forum: Friction Applications on Brakes/Clutches
Requirement of Water Flow Meter for Boiler
08/10/2009 11:06 AM
We need water flow meter to check the boiler feed water qty in the boiler.
boiler capacity 10mt/hr
feed water temp 90c
kindly advise
Pathfinder Tags: dairy
Re: requirement of water flow meter for boiler
08/10/2009 11:26 AM
Contact instrument suppliers directly.
Depending upon line size, the vortex shedding method of measurement is fairly good value these days for an installed instrument.
Do not go for an electromagnetic flowmeter unless the conductivity of the boiler feed water is above the suppliers' minimum for that style of instrument.
If a non-invasive or temporary method of measurement is needed, then clamp-on ultrasonic would be a good choice of method.
08/10/2009 12:48 PM
dear sir
thanx for your quick response pls explain vortex shedding method
with warm regards
sps sawhney
08/11/2009 3:18 AM
http://en.wikipedia.org/wiki/Flow_measurement#Vortex_flowmeters
.......and there is no need to be so formal in this forum.
Register to Reply 3 comments
