Previous in Forum: Balancing Rotors vs. Balancing Reciprocating Bodies   Next in Forum: Theoretical Measurement of Fan Flow Rates
Tip Velocity Limitations for Cast Materials
08/10/2009 11:50 PM
Hi
Is there any relation between tip velocity and material of construction while desiggning a impeller of a pump. If Yes ,please help me with the topic amd material available on the net.
Re: Tip Velocity Limitations for various Cast materials
08/11/2009 3:56 AM
More information from you would have gotten a better answer from me.
Start here: www. pumps.org
08/11/2009 7:33 AM
Hi
This is in context of Centrifugal Pump Impeller design. I have been told that Cast Iron can be used upto 680 mm Impeller diaat 1460 rpm. Similarly Bronze has the limitations.
Please guide me if it hold good or not.
Regards
Mahipal
08/11/2009 10:55 AM
<Gulp> that's some horse of a pump!
Good Answers: 19
Re: Tip Velocity Limitations for Cast Materials
08/11/2009 10:49 PM
Which pump company do you work for? If you are asking for design help, I do not want to buy pumps from your company.
If you are trying to cast a repair impeller for an existing pump, please don't. Find some way to obtain a replacement impeller from a reputable company who will back the safety of there product. Or hire an competent engineer in rotating element design to coach you and carefully advise your design approach.
Register to Reply 4 comments
lyn (1); mahipal (1); PWSlack (1); Ried (1)
