Previous in Forum: Tip Velocity Limitations for Cast Materials   Next in Forum: Practical Measurement of Torque
13 comments
Theoretical Measurement of Fan Flow Rates
08/11/2009 12:31 AM
I would like to know how one would measure the amount of air displaced by a normal ceiling fan running at its maximum speed, supposing we know its speed, swept length, blade angles etc.
Pathfinder Tags: fan
Re: Theoretical Measurement of Fan Flow Rates
08/11/2009 3:09 AM
Is the distance from the ceiling and other fixed objects also known?
08/12/2009 2:43 AM
slack, i wanted a theoretical measurement, so you could have safely assumed the data you required! (well, except for the flow rate).
08/11/2009 4:59 AM
Measure the air velocity at various points.
A ceiling fan is there to provide a subjective feeling of comfort which could be measured by the distribution and velocity of the air , not necessarilly the volume displaced.
Be careful to think carefull about what exactly you should measure.
'Theoretical measurement' is a somewhat confusing juxtaposition of words.
08/12/2009 2:48 AM
Del, what i really want is the amount of air displaced by the fan in a minute or something like that, but definitely not the velocity for the final answer.
Sorry for using confusing words, but i just wanted to know how one would go about the calculation with out using any instruments etc.
Good Answers: 58
08/11/2009 5:09 AM
Welcome.
I assume that as you use the word theoretical, you want some sort of calculation.
This example should get you started
08/11/2009 5:13 AM
Ha, I would counter that, by saying he uses the word 'measurement' and therefore want to do something useful .
Good Answers: 19
08/11/2009 6:51 AM
Theoretically he wants to design a box to catch and count units of air displaced, and is using the fan blade speed and geometry to prevent the box from impacting the fan blade and throwing the whole system out of balance!
Try to google propeller perfomance calculations, or look up some fan design books at the local engineering college library for fan design theory.
08/11/2009 7:03 AM
I still reckon my answer#2 is on the money.
It's not how much air you move, but where it goes.
Good Answers: 19
08/11/2009 12:47 PM
And what you do with it when it gets there!
My first reply was a weak attempt to reply to your trying to determine if he wanted a calculation to estimate air displacement or a method to try and measure the air displacement. My attempt at humor is sometimes too obscure. Sorry.
08/11/2009 1:19 PM
No, indeed, sometimes I'm so busy trying to be funny I miss other peoples humour..
Ha, we can have an apologising contest now.
Good Answers: 19
08/11/2009 5:05 PM
No please let me go first. I sorry you mis understood my feeble sense of humor. I'm afraid that as a wee lad I saw too many of the Monty Python shows you exported to the US!
08/12/2009 2:52 AM
Au contraire, entirely my fault.
I prostrate my myself at your feet and writhe hideously in the mire of abject misery.
(Yeah that should do it, it works with Mrs Cat)
08/12/2009 2:50 AM
Prof, thanx for the amazing info u provide, hopefully i could derive something useful for me from that. will start off by solving that problem. Thanx again!
Register to Reply 13 comments
kenichi (3); PWSlack (1); Ried (3); The Prof (1); user-deleted-1105 (5)
