Previous in Forum: Theoretical Measurement of Fan Flow Rates   Next in Forum: Vacuum Pump Problems
Practical Measurement of Torque
08/11/2009 12:36 AM
Is there any method to measure torque practically with simple lab equipment and not using any torque sensors or any other costly equipment?
Re: Practical Measurement of Torque
08/11/2009 2:45 AM
HAI MY E MAIL ID kkvijesh1985@yahoo.com
08/11/2009 3:59 AM
It is highly inadvisable to post an e-mail address in an international forum. E-mail addresses are easily harvested by spambots. They quickly bombard it with advertisements for non-prescription pharmaceuticals, scam requests to update on-line banking details, links to matters of an intimate nature and scams purporting to be about getting large sums of money out of Nigeria, rendering the address practically useless.
08/11/2009 3:09 AM
The simplest way would be with a simple torque wrench. They can be had for a few pounds at most automotive tool retail outlets.
08/11/2009 3:53 AM
A length of material with weights hung on it works just fine.
You need a rule and scales too, plus pencil and paper (or calculator). Ive measure motor stall toque of small Dc motors this way, a 1m bar connected to the shaft at it's centre (to maintain balance) add weights at one end until the motor won't turn when power is applied.
Simple is good.
08/11/2009 4:14 AM
You can get a rough idea with one of these ...
... and a spring balance. Be sure to fit the pipe wrench vertically so that it's weight doesn't muck up your result.
Not very good in the mNm ranges .
Good Answers: 103
08/11/2009 4:21 AM
1. As PWS said Torque Wrench
2. Input Power * efficiency/ RPM(converted to ω) will give you approximate value, assuming you are on a rotating shaft.
3. The other method is what is called the dynamic brake method where the torque is measured in terms of the force to stop. (A bit difficult to calculate because of the friction factor, as is the other method the pulley tension method)
Anonymous Poster (1); JohnDG (1); PWSlack (2); sb (1); user-deleted-1105 (1)
