Previous in Forum: DC System for Electric Substations   Next in Forum: Looking for a Limit Switch
Voltage Multipliers
08/10/2009 11:56 PM
I have to run a circuit for which the minimun input dc voltage is 3.5V but i have a battery of 1.2V so i want to get a circuit to triple the voltage(1.2V).
can anybody give cicuit related to this topic ?
Re: R & D ENGINEER
08/11/2009 3:23 AM
Buy two more batteries and wire them all in series?
It is highly inadvisable to post an e-mail address in an international forum. E-mail addresses are easily harvested by spambots. They quickly bombard it with advertisements for non-prescription pharmaceuticals, scam requests to update on-line banking details, links to matters of an intimate nature and scams purporting to be about getting large sums of money out of Nigeria, rendering the address practically useless.
Re: R & D ENGINEER
08/11/2009 4:44 AM
Try one of these. BTW I know nothing about electricity. Do you?
  1. Voltage Multipliers Any application that calls for a brief application of high voltage at infrequent intervals is a good candidate for a high-order voltage multiplier circuit. ...
    www.play-hookey.com/ac_theory/ps_v_multipliers.html - Cached - Similar -
  2. Diode Voltage Multiplier Circuit :: Radio-Electronics.ComCircuit and design considerations for a diode voltage multiplier.
    www.radio-electronics.com/.../circuits/...voltage_multiplier/diode_volt_mult.php - Cached - Similar -
  3. Voltage multiplier - Wikipedia, the free encyclopedia Jun 30, 2009 ... A voltage multiplier is an electrical circuit that converts AC electrical power from a lower voltage to a higher DC voltage by means of ...
    en.wikipedia.org/wiki/Voltage_multiplier - Cached - Similar -
  4. Jochen's High Voltage Page : Basic multiplier circuits Dec 30, 2004 ... Besides this, the advantage of the Villard circuit is that it may be cascaded to form a voltage multiplier with (in principle) arbitrary ...
    www.kronjaeger.com/hv/hv/src/mul/ - Cached - Similar -
  5. Voltage Multipliers, Inc. - Multiplier Design Steps Mar 26, 2009 ... Half Wave Voltage Multipliers Schematics. Half Wave Series Multiplier Most common circuit. Very versatile. Uniform stress/stage on diodes ...
    www.voltagemultipliers.com/html/multcircuit.html - Cached - Similar -
  6. Voltage multipliers : DIODES AND RECTIFIERS A voltage multiplier is a specialized rectifier circuit producing an output which is theoretically an integer times the AC peak input, for example, 2, 3, ...
    www.allaboutcircuits.com/vol_3/chpt_3/8.html - Cached - Similar -
  7. DC Voltage Multiplier Circuit Plans - Electric Circuit Build a circuit to boost the voltage of a DC power source using a MAX756 IC Chip.
    www.reuk.co.uk/DC-Voltage-Multiplier-Circuit-Plans.htm - Cached - Similar -
  8. AccessScience | Voltage-multiplier circuit Diode-capacitor voltage-multiplier circuits. (a) Negative voltage doubler. Diodes pass conventional current only in the directions of the. ...
    accessscience.com/search.aspx?rootID=798226 - Cached - Similar -
  9. Voltage-multiplier circuit: Definition from Answers.com voltage-multiplier circuit ( ′vōltij ¦məltə′plīər ′sərkət ) ( electricity ) A rectifier circuit capable of supplying a direct-current output.
    www.answers.com/topic/voltage-multiplier-circuit - Cached - Similar -
Good Answers: 18
Re: Voltage Multipliers
08/11/2009 3:04 PM
The easiest way to do this is to put three 1.2v batteries in series, but if you want to turn this into a project, then this site has schematics for several DC Boost Circuits using just about every method one could imagine to light an 3.3v LED with a single AA battery:
http://www.cappels.org/dproj/PulseBoostLED/Pulse_Boost_White_LED.html
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
08/11/2009 6:00 PM
1. Hook up a switch to the + of the battery and run that wire to a transformer.
2. Hook the - of the battery to the other side of the transformer.
3. Turn the switch on and off very fast.
4. hook up the secondary of the transformer to a bridge rectifier circuit.
5. viola!
08/13/2009 2:56 AM
You are too stupid to inhale correctly.
Reply Score 1 for Off Topic
Anonymous Poster (2); EElectrician (1); lyn (1); PWSlack (1)
