Previous in Forum: Impact Test for EFW Line Pipes   Next in Forum: MS Fittings
How Do Milling Machines Work?
08/11/2009 2:06 AM
how does milling machine works?
Good Answers: 103
Re: mechanical
08/11/2009 2:14 AM
There is a spindle and that is driven by a motor through a gear (or other mechanisms).
In the end of the spindle is a taper (and that has to be defined as ISO 50, ISO60, JIS, MT or other standards) In this taper the milling cutter locks. And then as the spindle rotates the so does the cutter. And the the cutter cuts the material.
BTW : this is an engineering forum, not for below highschool children.
Re: mechanical
08/11/2009 2:39 AM
No, no ,no ..
You put grain in the top and it falls between two big rotating stones through a hole in the upper one. It is ground into flour and exits at the periphery of the stones.
Re: mechanical
08/11/2009 3:07 AM
One of these:
or one of these:
The first is driven by wind, the second by electrical power.
Good Answers: 19
Re: mechanical
08/11/2009 6:53 AM
Love your thoughtful and insightful reply! and the pictures!
Register to Reply 4 comments
PWSlack (1); Ried (1); sb (1); user-deleted-1105 (1)
