Previous in Forum: Software for Concrete   Next in Forum: Weight-Balanced Automatic Splash Pool
Civil Construction
08/12/2009 3:57 AM
dear sir
what is the thumb rule of construction may i know the use of bricks,cement,iron, etc for covering 1square meter area
kindly advise
sps sawhney
Re: civil construction
08/12/2009 4:14 AM
The number of bricks to be used to cover 1m2 depends upon how high the stack is. The same is true of the other materials. So the question needs re-phrasing before a sensible answer can be given to it.
Good Answers: 101
08/12/2009 11:09 AM
There's none. Everything will depend on your local code of practice and the architect's and engineer's design.
Re: Civil Construction
08/12/2009 11:32 PM
"1square meter area",is it horizontal or vertical?
08/13/2009 9:47 AM
Number of bricks = 1 square meter / area of one face of the brick in square meter
08/26/2009 1:52 PM
DEAR SPSSAWHNEY, these can be calculated in cubic meter and not in sq. meter
08/26/2009 8:43 PM
thanx
Register to Reply 6 comments
babloobarjinder (1); DVader1000 (1); lyn (1); PWSlack (1); RTFVerterra (1); spssawhney (1)
You might be interested in: Bricks, Cement Boards, Cement, Concrete and Mortar
