Previous in Forum: Spectrum of Moonlight   Next in Forum: Dodge Diesel Starting Issue
9 comments
Popular Science - Weaponology - New Member India - Member - New Member
UV Purifier
08/12/2009 6:17 AM
Dear all.
I have some problem with my home water purifier. It is UV purifier. There is some sparking noise coming. I checked for any short circuit possibility. but it is OK. the UV tube also OK. i googled lot more to get basics to check the electronics behind the UV tube. Can anybody suggest some tips/ sites or steps to troubleshoot the purifier.
Re: UV Purifier
08/12/2009 6:22 AM
How long ago was the lamp last changed?
Is there a smell coming from the control unit?
Taking the top off the control unit in subdued ambient light, is there sparking or glowing coming from any of the terminals or components when power is re-applied?
Re: UV Purifier
08/12/2009 7:15 AM
The lamp [philips 8 W ] is original supply from mfg. [ Unit purchased 10 months ago]
No there is no smell only some noise [ chit chit ] coming. The lamp is also glowing as usual.
One more question. What prequastion should i take, to start/check the uv system in dismenteled conditions. [ i. e. out of enclosure]
Re: UV Purifier
08/12/2009 7:37 AM
<....What prequascaution should i take, to start/check the uv system in dismenteantled conditions. [ i. e. out of enclosure]...>
There will be live parts at line voltages present, so these must not be touched without the risk of electric shock.
It may be that the unit is working correctly after all, and that the noise is coming from something like a mains transformer, which do rattle from time to time.
If it is still under warranty from where it was purchased, contact the supplier for advice before invalidating any warranty by breaking any seals on the enclosure.
Re: UV Purifier
08/12/2009 3:37 PM
Its been awhile, if the lamps are bad and need to be changed out, do not touch with bare hands, the oil residue left will effect and burn out the lamps....same with halogen lamps.
Re: UV Purifier
08/13/2009 10:17 AM
As a non-english speaker I know that "chit chit" would more likely be the sound of arcing (arking?), the OP should check all hi voltage wiring insulations and bare conductors that might be too close to each other.
Yahlasit
Re: UV Purifier
08/13/2009 3:13 AM
DO NOT look at the UV tube while glowing. It may harm your eyes.
sisira
Good Answers: 73
Re: UV Purifier
08/12/2009 12:19 PM
Also keep in mind that the UV light emitted by this lamp is likely to be UVC which is bad for your eyes. Do not stare at this lamp while operating.
It also sounds like it is a type of fluorescent lamp (low pressure mercury vapor gas discharge lamp). That being the case, it consists of a ballast (current limiting inductor unless it is a newer electronic type) and a starting switch in parallel with a capacitor. The purpose of the capacitor is reduce noise. It may be the defective component. If the starter was defective, the lamp would fail to start or attempt to restart after it was already operating. Beyond that I would need more information.
Incidentally, in a particular failure mode, (one electrode damaged) a fluorescent lamp can actually act as a diode by allowing current flow in one direction only. It usually only does this for a short time before it reaches end of life. That can charge up a capacitor until it reaches breakdown voltage.
Re: UV Purifier
08/13/2009 2:13 AM
Trying spraying the electronic circuits with some pcb lacquer.
Good Answers: 25
Re: UV Purifier
08/13/2009 8:51 AM
If there is a transformer in the circuit just check if it is O.K. It may be making such noise.
Register to Reply 9 comments
Anonymous Poster (2); NotUrOrdinaryJoe (1); phoenix911 (1); PWSlack (2); sanjaykangralkar (1); Sisira (1); suresh sharma (1)
You might be interested in: UV Filters, UV Sensors, UV Curing Equipment
