Previous in Forum: Air Column Compression Measurement   Next in Forum: Frequency Counter Design
Load Cell Connections
08/14/2009 10:27 AM
In weigh feeders why loadcells are connected in parallel ? How the o/p will be calculated ?
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: Load Cell Connections
08/15/2009 8:52 AM
Hi,
When you need more than one load cell to weigh something (usually because of uneven distribution of weight) you can read each cell with a different measuring device and then calculate or connect them in parallel to just one measuring device and get the average value, the the weight must be the measured value times the number of cells.
Kind regards
08/15/2009 9:52 PM
thx for ur reply
But my doubt is while connecting parallel how it would give average value
can u explain it with a diagram
thx and regards
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
08/17/2009 2:52 PM
I could be wrong, but your request resembles homework one.
Depending on particular load receipt device's design(aka weighing platform) a parallel connection of load cells (2,3,4) is goaled to get the same stable average output signal in mV when excitation circuits wired in parallel. That is wherever the actual load(weight) is applied over platform it's supposed to deliver the same average analog signal measured in mV. Actually it's a quite "economical" approach as you need only one excitation PS source and just one ADC channel for further weighing(feeding) processing.
I'd remain this to you to find out any schematics of. It's believed to be not that hard today.
regards, caramba.
P.S. I thought you was interesting in strain gauge load cells.
Good Answers: 183
08/18/2009 1:46 PM
each load cell can be considered as a load proportional source. If you put all those tensions on a resistor and measure the difference in voltage between its ends it will be proportional to the summ of the load cells outputs so that you measure the effect of the whole load.
08/18/2009 2:17 PM
Hi nick name,
your input was to the very point as usual. Hope you're doing well.
Vlad.
caramba (2); jyothi menon (1); Kwetz (1); nick name (1)
You might be interested in: Stock and Strip Feeders, Solids Feeders, Parts Feeders
