Previous in Forum: Wanted: Pressure Meter with Timing Function   Next in Forum: Concrete and Building Exteriors
9 comments
Fire Protection Code
08/15/2009 12:36 AM
what is the relating code that can give guides for installing a fire protection wall to prevent fire to reach camp 8 meter away from diesel fuel tank 50000 liter capacity.
regards
Re: Fire Protection Code
08/15/2009 8:21 AM
Hey! You still haven't told us where you are. What is with all the secrecy? Is this some military operation?
CONSULT THE LOCAL AUTHORITIES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Unless you've put them all in jail! Jerk!
08/15/2009 8:26 AM
it is a fuel station in oman
no military
please if you can help ,do
08/15/2009 10:00 AM
You might try here: ROYAL OMAN POLICE WEBSITE - ROP History Events 22/78 pertaining to the issuance of Customs Code. Feb-1979, The opening of the Fire Training School at Royal Oman Police Academy, Nizwa (now the Sultan ...
www.rop.gov.om/english/rophistoryevents.asp - Cached - Similar
08/15/2009 11:28 PM
You may want to start with reading NFPA - 101. This will probably lead you to further applicable codes. Good luck.
08/16/2009 9:18 AM
wrong country
Good Answers: 58
08/17/2009 4:02 AM
P911
Why wrong country? This is a good place to start as Duane Tilden says, many countries and standards refer to the NFPA.
The mission of the international nonprofit NFPA, established in 1896, is to reduce the worldwide burden of fire and other hazards on the quality of life by providing and advocating consensus codes and standards, research, training, and education.
The world's leading advocate of fire prevention and an authoritative source on public safety, NFPA develops, publishes, and disseminates more than 300 consensus codes and standards intended to minimize the possibility and effects of fire and other risks.
NFPA membership totals over 75,000 individuals around the world and more than 80 national trade and professional organizations.
08/17/2009 5:45 AM
And then the American gets bashed for assuming this was a American thing..
Did not know that it was international. Now I can get bashed for that. Bash away...
Thanks for the info
phoenix911
Good Answers: 68
08/16/2009 9:16 AM
Hello mostafa,
Not sure if you are talking about a Military build or a 'Holiday Camp' build?
However, take any advice you glean from these sites as [b["ADVICE" only!
If you are in the Military you should have access to the relevant codes for safety, though from my experience, it is usually a local Architect who sorts these kinds of builds out. And or also contact the local Council or State Dept[, and Fire Deptp] [b[Bearing in mind local topography, drains, other dangerous flammables or explosives etc
Can you actually tell me where you are and are you the builder?
Fuel Tanks: Providers and Solutions | Business.com
Storage Tanks: Water Tanks, Fuel Storage Tanks | Business.com
Get advice from our guide to business water tanks and storage tanks. ... Manufacturer of fuel storage tanks and fuel tank related equipment products. .... steel tanks, tank calculator, aircraft refuelers, and fire protection tanks . .... Search for tanks from 500-50000 gallon capacity at SuperSafe Tanks Inc. ...
www.business.com/directory/.../tanks.../storage_tanks/
- Cached - Similar -
Tanks, Containers & Vessels - Manufacturers & Suppliers Directory Completely pre-engineered and designed for gasoline, diesel, fuel oil and aviation fueling applications ranging from 250 to 50000 gallon capacities. ... Field Erected Steel Storage Tanks For Industrial, Municipal, Fire Protection, Governmental. ... Supplier of polyethylene tanks, poly safe double wall tank systems, ...
www.industrialleaders.com/listings/tanks_containers.html
[PDF] STIP3 Cathodically Protected Underground Storage Tanks File Format: PDF/Adobe Acrobat - View 50000 gallon capacity. The system is pre-engineered and your tank is completely fitted ... Guide Specification. Modern Welding Company STIP3 Double Wall, ... NFPA 30 and 30A, National Fire Protection Association Flammable and ... Tank shall be capable of storing gasoline, gasohol, jet fuel, avgas, diesel fuel or ...
www.modweldco.com/...Tanks/Consolidated%20STIP3%20Info.pdf
- Similar -
Public wasn't notified of toxic waste spill 17 May 2008 ... 50000-gallon tank collapsed March 25. By ROBERT McCLURE ... As recently as May 7 , the agency put one out when an oyster boat spilled 75 gallons of fuel. A 435- gallon diesel spill at a fish processor last year merited two. ... The Environmental Protection Agency and Seattle Fire Department also ...
www.seattlepi.com/local/363554_spill17.html
2WD Crew Cab (C4E042) - 2009 Medium Duty Truck Online Order ... (6.8 kg) pressure cap, low coolant level light and alarm, surge tank and all- season ... warning (X55) without shutdown on Ambulance and Fire and Rescue Packages. ..... Includes a 6 mm 50000 psi (344700 kPa) yield strength, steel frame, ... NLE, 60-gallon (227L) fuel capacity - gas or diesel, with driver side fuel ...
eogld.ecomm.gm.com/.../proddesc.jsp?year...1...
[PDF] Iowa State Fire Marshal Division [Flammable and Combustible Liquid ... File Format: PDF/Adobe Acrobat - View National Fire Protection Association as the rules governing flammable ... 30001 to 50000 ... "No connection to storage tanks at motor fuel dispensing facilities ". ... steel inner tank with an outer containment tank wall constructed in ... diesel, and oil) storage tanks that are greater than 1100 gallons in capacity ...
www.dps.state.ia.us/fm/flammable/PDFs/Bulk_Fueling_Facilities.pdf
- Similar -
[PDF] Page 1 Page 2 5.12 Hazardous Materials Handling SECTION 5.12 ... File Format: PDF/Adobe Acrobat - View as HTML inside fuel and lubrication service trucks. Paints and solvents will be stored in .... Aqueous ammonia will be stored onsite in one 50000-gallon tank. ... walls. The spill containment walls will be designed to contain the tank volume plus an ..... Fire Protection Guide on Hazardous Materials. Twelfth Edition. ...
www.energy.ca.gov/sitingcases/.../TESLA_CHAPTER_5_12.PDF
- Similar -
ATSDR - PHA - Naval Air Station Whidbey Island (Ault Field and ... Estimated 50000 to 70000 gallons of unburned fuels may have been discharged to the ground. ... Currently, the area is grass covered with no visible evidence of fire, ... Jet fuel storage tank piping leaked near south west corner of test cell and ... JP-5, diesel, AVGAS, No. 1 and No. 2 fuel storage, mid-1970s-. ...
www.atsdr.cdc.gov/HAC/PHA/whidbey/whi_p4.html
NOTE: We on CR4 can only give you advice, ..................... On where to find advice. Any subsequent action by you must be done with the agreement of any local Jurisdictions.
Good luck and be safe!
08/17/2009 3:40 AM
Try using NFPA 850, that has guidelines for building fire walls around power station transformers. The principles can be applied elsewhere too.
Continuous Learning
Register to Reply 9 comments
babybear (1); Duane Tilden (1); lyn (2); mostafaalkholy (1); phoenix911 (2); sv13 (1); The Prof (1)
