Previous in Forum: Resin Bead Treatment   Next in Forum: Drop Test on PVC Profiles
Food-Safe Copper Pipe Cleaning Solution?
08/19/2009 2:41 AM
we manufacture milk testing equpment and we used copper pipe for that, we want to clean copper pipe inside for milk contamination. which type of soulution we can used for that ?
Re: COPPER PIPE CLEANING SOluction
08/19/2009 3:22 AM
Copper pipe???
Surely you should be using stainless steel?
08/19/2009 3:27 AM
but for our machine we used only copper pipe then we analyze milk contain properly.
please advice me which chemical used for cleaning the copper pipe for milk contamination?
08/19/2009 7:34 AM
Here is a materials compatibility database.
Copper has corrosion products that can be poisonous to biological systems. It is also relatively soft, and can erode in contact with some foodstuffs.
Sanitarily-polished stainless steels need to be used for metallic equipment that is in contact with human foodstuffs, for any corrosion products are relatively benign. Water-for-injection, for example, is kept in sanitary stainless steels at elevated temperatures, and hydrogen peroxide is used to sanitise them and their associated pipework at intervals. Flushing to remove all traces of hydrogen peroxide after the sanitisation is essential, as hydrogen peroxide is itself poisonous to biological systems, which is why it is used.
08/20/2009 2:39 AM
It is assumed that the unit is a test equipment and the milk after testing will not be consumed. If there is some thermal conductivity issues and copper is needed, can you plate this with Chromium-Nickel.
The best cleaning agent is hot water and Teepol followed by a water rinse. Teepol is a neutral detergent used for surgical cleaning and for general cleaning in the medical devices industry. It is itself non-corrosive.
Bioramani
bioramani
08/20/2009 5:00 AM
thanks for your reply. can this Teepol clean milk contamination in Copper pipe ?
08/20/2009 11:02 AM
Yes. It can. It can degrease and remove even vegetable and mineral oils and greases. It is freely available all over India. http://www.alibaba.com/member/in102122514.html bioramani
bioramani
Register to Reply 6 comments
bioramani (2); PWSlack (1); SHRIDHARMEHTA (2); user-deleted-1105 (1)
